Re-program the ECM?
Old Dec 22, 2017 | 06:23 PM
Huggerbugger's Avatar
Huggerbugger
Default Re-program the ECM?
Custom pipes installed. Instructions say to "Reprogram the ECM". Dealer?
Old Dec 22, 2017 | 06:31 PM
MURPHCC1's Avatar
MURPHCC1
NAh......that wont help.......POWERVISION or some other type of tuner......with just pipes i doubt if you need a tuner........if you also went with a high flow air cleaner (stage 1) YES for the tuner.......from the factory all these bikes are running really lean.......tuner richens it up so it runs better and cooler.......id get a tuner if your gonna be adding flow stuff.
Old Dec 22, 2017 | 07:29 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The dealer retune is mandated by EPA to bring the bike back to the EPA requirements with your mods to your model.
Old Dec 22, 2017 | 07:40 PM
rbdub474's Avatar
rbdub474
Screw that. The stock tune is crap and bad for your motor because of EPA regulations. Same reason stock air cleaners route spent crank case air back through the intake. Hot, oxygen depleted and oil laden air being fed into your intake. Does that sound like the type of air you want going into your cylinders? I’d much rather vent the crank case to atmosphere and have cool, clean air in my intake.
Get a good aftermarket tuner and make it run right. Only reason you would need to worry about it is if you live in a communist area that requires smog testing.
Old Dec 23, 2017 | 06:45 PM
seniorsuperglideE8
I'm not saying you have to take it back to the dealer but that's what the dealer would do as a retune/reflash. Get an aftermarket tuner and tune your bike with that. +1 with the external breather tubes.
Old Dec 23, 2017 | 09:08 PM
Mchad's Avatar
Mchad
Bike? Year?
Dealer stage 1 tune will keep you from getting into the “lean enough to eventually cause damage” area, but it’s far from optimal to reduce heat and make most power.
notsosmart
Jan 2, 2018 11:04 AM
DSLKSL
Jun 13, 2015 12:45 PM
rickurt
Mar 22, 2015 09:07 PM
nashvegasmatt
May 31, 2014 03:48 PM
Geoff
Dec 5, 2010 11:22 PM
