Snapped bolt (just venting)
Old Dec 29, 2017 | 10:25 AM
SC07Bobber's Avatar
SC07Bobber
Default Snapped bolt (just venting)
So I just about finished my 107 build. I've been working outside in freezing temperatures. Not fun but it is what it is.
All was going well buttoning it up. Then the notorious big sucker standoff bolt....SNAP!!!! We've all done it. I've done it before. And yes there's tons of threads on it.
So the 1/4 x 20 threaded stud is broken off in the throttle body hole. It's not flush but rather inside a few millimeters so I couldn't grab it. I even found and purchased the new studs at a local shop.
Now the notorious punching, drilling and extraction efforts began.
No dice! I can't get a good center punch or pilot hole started due to the irregular surface (not flat).
So the center bits, reverse extractor bits and all couldn't make a dent. Yes I used oil. No luck.
That, plus the bike, TB and screw are all about 15 degrees F.
Looks like I should remove the TB and take it to the local machine shop to use a drill press and get it done the right way; before I mangle up the face any more than I have done already.
Anyway. Just pissed off. I would've really have liked to put the tank on and be done. Oh well.
It's all part of the game!!!
Old Dec 29, 2017 | 10:44 AM
HrdNox's Avatar
HrdNox
Ya,taking it off is probably a good idea. Not like your in a hurry to get out and ride anyways. -2 here so yea,I know what cold is haha! Good luck!
Old Dec 29, 2017 | 10:51 AM
SC07Bobber's Avatar
SC07Bobber
No rush? Hell yeah there is. Can't wait to get this build started and seat those rings well. There is an annual polar run on New Year's Day I was looking forward to. Ugggh. But, better safe than sorry. Starting this new build at these temps is probably not a good idea. Gotta wait for the oil to look less like thick honey.
Old Dec 29, 2017 | 11:26 AM
cggorman's Avatar
cggorman
Don't need no stinkin air cleaner in the winter, anyway.
Old Dec 29, 2017 | 02:51 PM
Ghost_13's Avatar
Ghost_13
Sharpen a small punch / awl - take it and a ball peen - see if you can tap them out
Ghost
Old Dec 29, 2017 | 03:23 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
My thoughts are the air filter side of the throttle body has that paint-on type of loctite from the original bolts. That stuff will regrab those studs.
My experience is hit the stud with heat from a heavy heated solider tip. Then after it cools, a drop of PB Blaster. It should be loose then. If not, where it snapped is dug in. PB Blaster or other printitents will not help until the loctite is cooked
Old Dec 29, 2017 | 04:01 PM
cggorman's Avatar
cggorman
If I can't walk it out with a punch, I go straight to a carbide burr to get a pilot divot started before moving to a carbide drill. Guide bushings are extremely helpful, too.
Old Dec 29, 2017 | 04:06 PM
72 Ironhead XLH's Avatar
72 Ironhead XLH
Just what are you using to tighten a 1/4 x 20 bolt and how tight are you trying to go
Old Dec 29, 2017 | 04:35 PM
SC07Bobber's Avatar
SC07Bobber
All fixed.
Drilled out and helicoil ; magic.
now I can put the tank on and be done.
Yayyyyyyy.
Old Dec 29, 2017 | 05:54 PM
Gearhead88's Avatar
Gearhead88
I've seen those broken several times , Ness big sucker right ? They usually break while you are riding . The 1/4"-20 studs that come in the kit are too brittle.
