Hey guys 2014 FXDL here, bike has been sitting for a few weeks due to weather and I finally had the chance to do a short ride yesterday after my gauntlet fairing install.
When i left out everything felt fine but about 5 miles into my trip I noticed the front brake lever was very stiff to pull and had no play at all. as soon as you touched the lever you were braking. In fact i can always hear a whistling noise from my front brakes only when applying them and i could now hear it all the time so it seemed to be dragging the brakes lightly. After a few miles of this everything went back to normal, no noise and lever pull was back to how I'm used to feeling it.
I will say I have had issues with my brake lights staying illuminated recently and now this makes me think it might be time to rebuild the front master cylinder and bleed the brakes.
Could there possibly be debris in the housing binding the lever movement
To follow up with what Ghost said when was the last time your brake fluid was changed? Also what color is the fluid? I think it is recommended to have the fluid changed every 2 years.
No ABS, I forgot to mention that. I didn't get time to check it over real well after the ride but I will check for debris caught anywhere. Figured I would start with rebuilding the master cylinder since the rebuild kit is so cheap and while I'm at it replace the brake fluid. The bike will be 4 years old in May
