Andrews 57H cam's installed
Old Feb 16, 2018 | 02:05 PM
NO4NJNK's Avatar
NO4NJNK
I do run the FP3 from time to time in different weather so I can see how the temp of the bike reacts and to check horespwer and torque. I haven't done an autotune with the new cam's because its running so well. I would hate to mess the map up at this point.
Old Feb 16, 2018 | 03:16 PM
Redbeard's Avatar
Redbeard
Originally Posted by NO4NJNK
I did run the stock baffles for a short time. Bike ran great but the sound just wasn't what I was looking for. I want a sound that will turn heads when I fire her up. I finally got that sound with the BCT.
I had BCTs on my last bike so I know how good and deep they sound. I'm considering those pipes, so just wondering what was lacking with the stock Cobra baffles.
Old Feb 16, 2018 | 05:24 PM
NO4NJNK's Avatar
NO4NJNK
They sounded good, but not "quality loud" enough for me
Old Feb 16, 2018 | 06:22 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
My only concern is with the low idle is there sufficient oil pressure getting to the lower end and the charge rate for the battery could be a little low.
Old Feb 16, 2018 | 09:12 PM
NO4NJNK's Avatar
NO4NJNK
My mechanic at Gemini cycles in Horn Lake, Ms said at 920 rpm everything checked out fine.
Old Feb 16, 2018 | 09:31 PM
Lifestarts@40's Avatar
Lifestarts@40
How's the valve train noise? Is it about like stock or noisier?
Old Feb 17, 2018 | 08:44 AM
NO4NJNK's Avatar
NO4NJNK
If you ask me, the valve train noise is noticeably quieter. I believe that's because of the S&S quickie adjustable pushrods.
Old Feb 17, 2018 | 10:00 AM
iceman4160's Avatar
iceman4160
Just curious why you went with the chain drive cams versus going with gear drive like the 54's or 60's and getting rid of the hydraulic chain tensioner. The RPM range is pretty close with all of these.
Old Feb 17, 2018 | 06:38 PM
NO4NJNK's Avatar
NO4NJNK
Because, when I was deciding on going with the gear drive first. I researched all I could. Like, if my crankshafts runout was above 10 thousands, I would have to have the crank reworked to get it below 10 thousands in order for the gears to keep from destroying themselves and everything else. This was my first time doing this and chose the safe and sure thing of the chain drive. My chain tensioners didn't really show much sign of wear after 13,000 miles. So, im glad I made "My" right choice.
Old Feb 17, 2018 | 09:40 PM
iceman4160's Avatar
iceman4160
Cool, that's all that matters, is making the right choice for you.
