Measuring axles
Old Mar 13, 2018 | 01:07 AM
Cathleen Brill's Avatar
Cathleen Brill
6th Gear
Default Measuring axles
I bought a wide glide front end but didn't get a axle and want to know how to measure for a new axle
Old Mar 13, 2018 | 04:25 AM
Krazy8s's Avatar
Krazy8s
Year of manufacture would be useful. You could probably look it up in the manual once that's known.
failing that you could measure the diameter of the axle mount hole at the end of the forks and extrapolate from there.
Old Mar 13, 2018 | 06:50 AM
JayStronghawk's Avatar
JayStronghawk
Knowing the Year your New Front End is will certainly help .. 2000-2007 Models were 1" Bearings .. 2008 Up are 25.8MM" which is very close to 1" ..
Old Mar 13, 2018 | 07:38 AM
Cathleen Brill
6th Gear
Default Axle length
I have a 2001 Dyna lowrider but I bought a wide glide front end online and it didn't come with a axle the slider say showa but it looks like a roadking
cvaria's Avatar
cvaria
start here:
https://shop.outpostalaska.com/OEMpartfinder.htm
Old Mar 13, 2018 | 07:41 AM
Cathleen Brill
6th Gear
Default Axle length
Ty I'll try that's
Old Mar 13, 2018 | 08:01 AM
Tom84FXST's Avatar
Tom84FXST
All you need to do is measure the "hole" for the axles...it will be 3/4 or 1"
The 25mm and 1" axles fit the same sliders...the inner spacer will work for 1' or 25mm...but the axle and the bearings must match...when you actually install the wheel.
Old Mar 13, 2018 | 09:15 AM
multihdrdr's Avatar
multihdrdr
Originally Posted by JayStronghawk
Knowing the Year your New Front End is will certainly help .. ̶2̶0̶0̶0̶ 2006-2007 WGlide Models and 2004-2007 Other FXD Models were 1" Bearings .. 2008 Up are ̶2̶5̶.̶8̶ 25 MM" which is very close to 1" ..
OP, post a Pic if you can
EDIT: If it's 3/4", plenty on eBay right now...cheap
https://www.ebay.com/sch/i.html?_fro...46-83B&_sop=15
Old Mar 13, 2018 | 09:46 AM
Max Headflow's Avatar
Max Headflow
08 ups are 25mm ID not 25.8mm.. Wheels used a standard sealed 6205 bearing unless there is ABS. Still the ABS bearings are the same size.
The axle size will depend on the wheel you plan to run. If the original Low rider wheel, you will need a 3/4 inch axle to fit your wheel and spacers for the wheel and disk rotor.
Old Mar 13, 2018 | 10:17 AM
multihdrdr's Avatar
multihdrdr
lol... You know Max, I really didn't even look at that quoted "25.8" ... I had my "blinders on" and was focusing on the 1" application specifics he listed
Of course the wheel plays a part, but don't forget the important part of what the sliders will easily allow you to do.
Most people won't be putting 25mm/1" axles into sliders meant for 3/4" axles
