Backfiring, stuttering, no acceleration
Old Mar 22, 2018 | 11:50 AM
nevil's Avatar
nevil
Another suspect could be a hole in the internal fuel tank line, and/or dirty fuel filter.
Old Mar 22, 2018 | 12:04 PM
Huggerbugger's Avatar
Huggerbugger
Fuel pump clogged.
Old Mar 22, 2018 | 01:38 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Did you put any fuel stabilizer in the fuel prior to letting it sit. Fired up two of mine the other day when it was warm out and they fired right up. Today's gas is crap, and ethanol phase separation is common when moisture is introduced to fuel tanks (think condensation). Get of the old gas, put in fresh gas with Sea Foam mixed in. Do this with a couple of tanks. I've got a feeling the injectors are varnished or gummed up.
Old Mar 22, 2018 | 01:41 PM
Huggerbugger
Probably right, Senior. Just found a set of new OEM injectors on ebay for $30.
Old Mar 22, 2018 | 03:30 PM
sweatymullets's Avatar
sweatymullets
1st Gear
As Jay Guild mentioned it could very well be the TPM. Most if not all fuel injected vehicles experience wear and tear on the TPM, and if left unchecked, will cause the vehicle to experience the symptoms that you have mentioned (a dip in gas efficiency is another one).
It's a pretty cheap DIY fix.
Check this article out for reference:
https://thebikersgarage.wordpress.co...-a-motorcycle/
Old Mar 22, 2018 | 03:32 PM
Locco's Avatar
Locco
Well I changed the plugs and drained the fuel and put more in with some fuel injector cleaner added. Still doing the same thing. Idles fine but any throttle and it begins to bog down, wants to stall and backfires. I actually had to buy a TPS just for the screws, so I guess I can swap that out and see what it does. I'm at a loss otherwise.
Thanks for all the suggestions.
Old Mar 22, 2018 | 03:42 PM
Jay Guild's Avatar
Jay Guild
When my TPS went bad I would be riding and the bike would start coughing and backfiring, and then I would have no throttle response until I twisted it hard and then it would act OK for a few minutes but then keep doing it. Hooked up the SERT and sure enough the TPS was reading 18% high at every position so I was flooding the engine without the intake valve open enough. This will give you a MAP sensor error as well because the pressure is not high enough for the air/fuel mixture that is too rich. If you don't have an interface to read the throttle position from the ECM:
Old Mar 22, 2018 | 04:22 PM
Locco's Avatar
Locco
I also just remembered I have a V&H FP3 installed. I've actually never used the app until today. Is there anything I can glean from the app which would help me troubleshoot, other than codes?
Old Mar 22, 2018 | 04:31 PM
Huggerbugger
Possibly.
Old Mar 22, 2018 | 04:32 PM
Jay Guild's Avatar
Jay Guild
Hell's yeah. When you get in to the app with the bike on and you are connected with the bluetooth there is a View Sensor Data button. Go in to that and in one of the corner circles there is a TPS position reading. It should be at 0 with a proper TPS. If it doesn't say TPS in any circle then you need to select one of the circles in the corners and change it to the TPS reading. Adding a reading as high as 5% is acceptable though.
