Backfiring, stuttering, no acceleration
Old Mar 21, 2018 | 04:04 PM
Locco's Avatar
Locco
Default Backfiring, stuttering, no acceleration
Hello everyone.
I have a 2013 Wide Glide which has basically been sitting since December. I've gone for a couple of rides and started it every week but otherwise it has been sitting. Since it's warmer I wanted to clean her up and take her out but on the most recent start it was stalling under throttle as well as sputtering and backfiring. I ran diagnostics and it came back with P0107, MAP sensor. I replaced that today and it is giving me the exact same problem and the same code is coming back. I've checked the wires and nothing appears broken or loose, so I'm not sure what the deal is. I checked the plugs (although I don't think that's really the issue) and they could probably use a change and I'm going to pick up some new ones tomorrow.
In the meantime, is there anything else which could be causing the problem?
Thanks.
Old Mar 21, 2018 | 07:18 PM
Cogswell's Avatar
Cogswell
Check your air cleaner for a mouse nest ?
Old Mar 21, 2018 | 07:54 PM
Locco's Avatar
Locco
I actually took it off today and cleaned it. Was a little dirty but no nests.
Old Mar 21, 2018 | 09:13 PM
nevil's Avatar
nevil
Check your battery terminal and ground strap connections. Any of those being a little loose or dirty can do those kind of things.
Old Mar 21, 2018 | 09:31 PM
Locco's Avatar
Locco
Also checked and clean with no loose connections or breaks.
Old Mar 21, 2018 | 10:08 PM
saltlick's Avatar
saltlick
shitty old gas, go fill it up to the brim wth some good stuff.
Old Mar 21, 2018 | 10:30 PM
Locco's Avatar
Locco
I was thinking this could be a problem. I haven't put any in since maybe January, but I also didn't think it would break down this quickly. I mean on the Walking Dead they are still driving around on years old gas.
Jokes aside, I will probably drain it tomorrow and get a jug to put some more in.
Thanks.
Old Mar 22, 2018 | 06:46 AM
Cogswell's Avatar
Cogswell
Thanks.
I usually find old gas to be an issue on carbureted engines, the fuel injection delivery system is not vented to the atmosphere. Of course there could be moisture/water or debris as well...
Old Mar 22, 2018 | 08:50 AM
Boostedboxer04's Avatar
Boostedboxer04
Definitely sounds like bad gas. Drain the tank and fill it up with premium and injector cleaner
Old Mar 22, 2018 | 11:42 AM
Jay Guild's Avatar
Jay Guild
Could be the TPS.
