FXDLS air flow
Old Mar 26, 2018 | 12:20 AM
WH1_T-type's Avatar
WH1_T-type
Sorry it is a 110 and I listed all mods in the OP. Didn’t list engine size size I listed bike type.
Ill talk to the mechanic tomorrow but if the stock TB and AC will provide adequate flow for now I’ll wait till I’m looking at bumping compression till I upgrade those parts.
Thanks for replies.
Old Mar 26, 2018 | 07:53 PM
Nickd2689's Avatar
Nickd2689
Thanks for replies.
the stock tb/ac are more than adequate. If you were gonna go with a larger displacement or forced induction, then it might make a slight difference. I forget if you said you were doing headwork or not but that would be a reason to upgrade it, though it still wouldn’t be absolutely necessary.
Remember, you have a cvo motor so you already have a good high flow air intake stock, if the 50mm wasn’t good enough they would have given us 58s from the factory.
Old Mar 26, 2018 | 09:29 PM
cvaria's Avatar
cvaria
Originally Posted by Nickd2689
my thoughts exactly.
well i saw an increase across the entire range on my 110 but, my hodgepodge is not the average bear.
Hd 58mm w/4.9in vs stock.
if you want 58mm, fn do it. Dont ask for permission. .. your bike.
Old Mar 26, 2018 | 09:45 PM
Nickd2689's Avatar
Nickd2689
Very true. Lol I think he was asking for advice/opinions though.
Old Mar 26, 2018 | 09:51 PM
NORTY FLATZ's Avatar
NORTY FLATZ
no argument over flow, with your knowledge on airflow and head upgrades and everything im by no means challenging you to a debate, however in my opinion, the cost of a new 58 mm (and one should upgrade to 5.3/6.0 injectors to go with it) is hard to justify since the 34% won’t equate to a 34% in power gains. Just my opinion....but I do have the 58 mm since it came with my 117 lol
We're in agreement here.
Don't forget, air velocity has as much to do with power change as the diameter. Maybe more...
Old Mar 26, 2018 | 10:00 PM
cvaria's Avatar
cvaria
should i... could i......
Old Mar 26, 2018 | 10:02 PM
cggorman's Avatar
cggorman
Intake manifold and heads matter more than throttle body. Cvaria's chart doesn't lie but I'm not sure it tells the whole story either.
Many good street throttle bodies actually have venturi throats (narrowed section) to increase velocity without increasing pressure drop (much). Helps with throttle response.
Intake and exhaust design is amazingly complicated. Fluid dynamics, thermal dynamics, acoustics (not sound-related), etc. I'm not smart enough to understand the nuances but I know they exist.
If in doubt, try it out. Just make sure each change gets a full retune. You can always go back.
My dad built drag racing engines. We had a dyno and a flow bench plus a full fab shop. He wprked with both NOS and Linginfelter in the 70s & 80s. Even with his considerable resources I couldn't even begin to count the number of test intakes, heads, cams, pistons, valves, etc we had laying around. Pallets full. Literally.
Old Mar 26, 2018 | 10:44 PM
brasher's Avatar
brasher
correct, Air Quality not quantity!
Old Mar 26, 2018 | 11:20 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by NORTY FLATZ
Just for comparison purposes, the 58MM will flow 34.5% more than the 50mm. Everything else being equal.
Technically you won't get 34.5% more flow unless you open up the manifold side. They are typically about 1.8 inches or about 46mm.. You still have to feed the air through that hole.. Anything above about 50-55mm, and low starts to level off.. If running 110 heads, you should see a power gain with the 58. While they can be made better, they do flow about 280-290 cfm at 28.. Stock TC 103 heads would be a waste of time. They flow 210 to 230..
Old Mar 27, 2018 | 06:17 AM
cvaria's Avatar
cvaria
This guy f***s!
pjbuilder
Jun 11, 2018 07:42 AM
vcm321
Mar 29, 2018 04:58 AM
Derik
Feb 14, 2018 11:15 PM
kingofsand21
Mar 11, 2010 08:00 PM
brickie
23
Jan 12, 2010 10:32 PM
