Fastener Conundrum
Old Mar 25, 2018 | 12:36 PM
Krazy8s's Avatar
Krazy8s
Default Fastener Conundrum
During my 103 build to date, which has turned more into a total bike restoration project, I've lost count of the number of "external to the motor" fasteners Ive broken or destroyed when removing due to the ole Dissimilar Metals quandary as well as rust/corrosion.
Clearly there are various fasteners that must or should have loctite applied regardless, but many others that would probably benefit more so with anti seize so as to avoid corrosion and rust problems.
Exhaust studs for instance, better to have a hi temp anti sieze?
Similarly for all other exhaust clamps and bracket bolts?
Other bolts that rarely cross your mind until you need to remove them such as headlight mount and engine mount bolts.
I won't go through a whole list of fasteners but you get my drift.
So any thoughts as to what other fasteners would be better off with anti seize, or is there a product out there that can perform like loctite but still prevent corrosion or rust related seizure?
Old Mar 25, 2018 | 01:33 PM
cggorman's Avatar
cggorman
Loctite is an effective anti-seize (anti-corrosive) and assembly lube. I saw an industry presentation years ago from Henkel (makes Loctite) with testing data for all kinds of scenarios and it was pretty amazing how versatile chemical threadlockers actually are.
Probably better off with anti-seize for the exhaust studs. I can't remember how hot the usual chemical threadlockers can go without breaking down.
As far as high temp anti-seize, I really like Henkel LB-8009. It's as close to a universal anti-seize as I've found. Good for all metal combinations and high temps.
Amazon Amazon
Old Mar 25, 2018 | 01:49 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Copper Plus by Kroon Oil, Karl....
To be used on all exhaust fasteners from jugs to tail, front & rear axel nuts, calliper bolts and brake pads (metal side).
Old Mar 25, 2018 | 02:08 PM
cggorman's Avatar
cggorman
Anti-seize selection and tech.
Loctite selection and tech.
autobite
Apr 20, 2015 09:02 AM
OceanState401
Dec 8, 2010 11:06 AM
snookums
Sep 7, 2010 01:27 AM
Adam_T
Sep 28, 2009 03:07 PM
scaryonly
Exhaust System Topics
Dec 3, 2008 03:33 PM
