No Spark 2001 Super glide 88ci
Old Mar 28, 2018 | 10:20 AM
Max Headflow's Avatar
Max Headflow
Originally Posted by Nomadmax
Max
And that slowing allows the CPS to see the two tooth gap on the left flywheel?
I don't think the slowing makes any difference on the gap.. Ignition sees it as long as the flywheel is turning.. The slowing is not as drastic as the gap. The ignition still needs the gap to figure the position of the crank. Where the slow down is, in reference to the crank, is where the ignition / efi figures that the rear cylinder is on compression.
Being a retired EE with some embedded background, it would be cool to see the code for the device.
Old Mar 28, 2018 | 11:21 PM
Krazy8s's Avatar
Krazy8s
Have you checked your spark cables?
For what its worth, a weak spark is the same as no spark, i.e. no start.
I had a similar deal with a spark cable resistance being about 10% over tolerance, enough to produce a spark but not enough spark to fire.
Healthy spark is a nice bright blue color, weak spark is white and often can't be seen easily in daylight leading you to believe there is no spark.
Old Apr 4, 2018 | 08:46 PM
SuperGlide206's Avatar
SuperGlide206
3rd Gear
New Crank Sensor, new battery, new coil pack, 12v to the center pin from ignition module to coil pack, cranking strong, still no spark. I guess its time to send it to a shop. I suspect its the ignition module still. I will let you all know once its running what the issue was. thanks for the responses
Old Apr 4, 2018 | 09:31 PM
Max Headflow
Do you have compression in the rear cylinder and the spark plug in?
Old Apr 4, 2018 | 09:39 PM
SuperGlide206
3rd Gear
yes good compression and new plug
Old Apr 4, 2018 | 09:48 PM
SuperGlide206
3rd Gear
It only has 25,000 miles on it. And was well maintained by previous owner.
Old Apr 5, 2018 | 08:21 AM
FPV's Avatar
FPV
Is it an early 2001? It might still have a cam position sensor. Not sure the exact month but sometime in '01 they omitted that cam position sensor. Is there a wire coming from the front of the cam cover? If so, that might be your problem.
xMPRx
EVO
25
May 11, 2025 10:01 AM
VanHalen
Sep 6, 2018 02:21 AM
Skiprrrdog
EVO
18
May 23, 2016 10:26 AM
Iron_Rookie
Ironhead
Apr 27, 2012 03:29 PM
zenwarrior
Oct 5, 2006 03:10 PM
