FXDLS Speedo/Tach mount relocation
I know I need a set of new gauge cups so does anyone have any recommendations? Do the gauge cups have a spot that can mount to a gauge mount like the Luck Daves?
And how about the covers to go over where the gauges are currently on the tank? I know Hard Case Performance makes them and I might go with those any other suggestions?
All that said, I know Big Bear Choppers has a complete relocation kit which is also an option. Curious if other FXDLS owners have made the switch and what they have done.
http://guerrillacables.com/2014-2017...arness-w-tach/
A member on here TheSSPirate did the relocation on his FXDLS - you should be able to find the thread if you look up his profile.
2361 x1 - screws to hold the back plate to the gauges (they come in a pack of 5)
67319-95 x2 - tach cover without the button hole
67344-97 x2 - rear rubber grommet
67345-97 x2 - front rubber grommet
67338-97 x1 - tach/speedo mount
Only other thing you will need is a T-Bar mount, and the wire extensions (I used the extender from Guerilla.)
Totally worth it. Best modification I've done to the bike.
To cover the dash, I used a piece of kydex. It is crude, but cheap.
The plate has a flexible tang on the back side that the PV will slide into. I used some double sided tape to keep it from sliding around.
