Vibration
Old Jun 22, 2007 | 01:38 PM
mcleary's Avatar
mcleary
Stage I
Default Vibration
I have recently developed a vibration in my front end. I have about 4500 miles on the bike. Has anyone else encountered this problem? I'm gvetting ready to go on a trip and would like to solve this problem. I'm not sure if the front wheel is out of balance or the neck bearings are loose from being broke in or drive belt loosened up.
Just looking for a little help before I decide to take it into the shop.
Old Jun 22, 2007 | 02:45 PM
BULLDOG88's Avatar
BULLDOG88
Default RE: Vibration
Don't goof around with this. Call around and get an apointment to have it checked. Those little weights can come off and put the front wheel out of balance. Wear over 4500 can require a rebalance.You may even need a new tire.If you have spokes (do not use this to start another thread) theymay need to be checked to be sure the wheel is true.
Cynic's Avatar
Cynic
If you could get the front wheel off the ground and with a little help to steadyyour bike you could check the steering head bearing adjustment. Also, you could spin the wheel to check for run-out and imbalance. As the wheel is spinning, rap the axle slightly with a small dead blow hammer or piece of wood to set up enough vibration to over come the seal friction.
Old Jun 22, 2007 | 02:53 PM
glide05's Avatar
glide05
ya - get that front end off the ground and check for play in the head.
also - remove the caliper (remove bolts and tie it to the frame) - and spin the wheel - check for play in the wheel bearings.
easy to spin wheel with caliper off.
Old Jun 22, 2007 | 04:24 PM
rh8234's Avatar
rh8234
Tire cupping, tire pressure, tread separation, runout, tire balance, loose spokes, stearing head bearing adjustment, motor mounts, could all cause a vibration. (Also check rear tire pressure, wear, runout....)
jqb12
Wheels/Tires
Mar 28, 2017 04:42 PM
tcarson84
Apr 12, 2016 06:12 PM
SalsaNChips
Wheels/Tires
Aug 19, 2012 09:22 PM
SalsaNChips
Aug 1, 2011 06:33 AM
thomasf59
Oct 4, 2007 08:27 PM
