Help bad mpg
Old May 3, 2018 | 12:30 PM
cggorman's Avatar
cggorman
Originally Posted by Ghost_13
Along w/ a proper tune...., OP, how much engine braking do you do - that eats up gas big time
Ghost
Harley ECU doesn't cut fuel on decel? That's lame. Maybe a cooling strategy?
Old May 3, 2018 | 12:39 PM
Crs2292's Avatar
Crs2292
Originally Posted by cggorman
Other than the tune, I'd look into intake and exhaust leaks at the heads and O2 sensor bungs. If there is unmetered air getting in there it could be read by the O2 sensors as a false lean condition which the ECU would try to correct by adding more fuel. Wouldn't hurt to test the (MAP, MAF, & O2) sensors, too.
would soap and water be the best trick to find a leak at the head thank you guys for all your input still new to Harley and so you guys are a big help
Old May 3, 2018 | 01:02 PM
Crs2292's Avatar
Crs2292
Ghost
Honestly I very early engine brake
Old May 3, 2018 | 01:09 PM
Crs2292's Avatar
Crs2292
Ghost
sorry ment I very rarely
Old May 4, 2018 | 09:31 PM
TexasScooterTrash's Avatar
TexasScooterTrash
A bone stock 07 should be getting mpg in the upper 40's. Previous Owner had go fast goodies on it and took them off. Your friendly HD stealer will charge to flash the ECU. Ask about the price of a Stage 1 flash upgrade. Should cost around $100/125. Good luck.
xfry
Carburetor Related
May 5, 2013 07:52 AM
akodust
Aug 15, 2008 01:07 PM
mrb302
Oct 3, 2007 09:06 AM
LarryJ00
Jul 24, 2007 01:22 AM
eno50
Jul 8, 2007 10:04 PM
