front end
Old Jun 26, 2007 | 04:10 PM
WS6 Formula's Avatar
WS6 Formula
Default RE: front end
ORIGINAL: thrillseeker
ORIGINAL: Cynic
Nobody saidthey wereadjustable!
WS6 was offering an alternative way to lower your Dyna a little by using WG trees and stock length Bob forks. I said H-D raked the trees a few degrees on two of it's Dyna models a tad for lighter, sharper steering on said models than they would have had without the raked trees. All else being equal, raked trees decrease trail, which sharpens steering!
All three trees carry different part#s, with the Wide Glide also being, what else beside more rake, wider.
Why are you being so persistent in denial of the fact after we took the time to explained?
if you are going to give out information on a web site, then you should be prepared to back it up. I am backing up my statement that the trees in every model except for the VRod, are 0 degree trees. If you take a tree set up from a WG, and put it on any other model, your rake, trail, etc, will not have changed because the are ZERO degree trees.
You can't use the limited information on the HD web site to conclude there is rake in the trees.
thrillseeker,
I have to agree with what you wrote above that I highlighted in bold, now go to the site below and read page 48. Then tell me what you think.
http://mysite.wanadoo-members.co.uk/...3/06Master.pdf
Old Jun 26, 2007 | 04:11 PM
glide05's Avatar
glide05
certainly not the first time this has been debated in this forum, and I've always been quite interested in the correct answer. Quite frankly - I don't think I've seen conclusive proof one way or the other. Proof to me would be an official HD document, or a picture of removed trees and stem, with a 90deg straightedge square with the bottom tree and touching the top of the stem.
My indy guy said that HD did mess with the tree rake on "later" model FXDWG, but he seemed kind of vague, so to me it was just another opinion.
Not trying to stir the pot here - but I'm still quirte interested in the correct answer.
Old Jun 26, 2007 | 04:19 PM
glide05's Avatar
glide05
WS6 -
I was typing my comments before i read your reply to the question -
thanks for the link - that's a nice document and explains quite a bit more than just the question at hand.
Old Jun 26, 2007 | 04:21 PM
Cynic's Avatar
Cynic
Go down to the dealer, go inside, walk over to the parked Dynas, take off your shades, have a looks see. It's also documented in official H-D literature somewhere, but I'm not wasting anymore time trying to remember where!
Old Jun 26, 2007 | 04:26 PM
thrillseeker's Avatar
thrillseeker
ORIGINAL: WS6 Formula
ORIGINAL: Cynic
thrillseeker,
Based on that, it certainly does appear that there is 2 degree's in the tree to account for the difference between head angle and fork angle.... so, for 2006 and up, I will stand corrected
I'm still standing by my position for years previous to '06. Do you have some similar reference for previous years?
Thank you for providing something concrete (at least for '06), this does come up somewhat regularly... so, I will need to change my response for the next time.
Glide05 - it appears your indy might have been referring to this change. I'm very interested in the truth as well. There is so much misinformation out on the web (about Harleys and everything else), I think it is important that we all try to be as acurate as possible.
Thanks WS6
Old Jun 26, 2007 | 04:28 PM
thrillseeker
ORIGINAL: Cynic
whatever
Old Jun 26, 2007 | 04:42 PM
Cynic's Avatar
Cynic
[blockquote]quote:
ORIGINAL: Cynic
[/blockquote]
whatever
Another know-it-all punk takes a full face plant in front of his peers
I guess this was backing it up?
The only HD model where rake is adjusted in the tree, along with the frame, is the
VRod
How about this?
measure the distance from the top of the frame neck to the top of the fork (just below the upper tree)
measure the distace from the bottom of the frame neck to the fork (just above the lower tree)
The distance is going to be the same (in other words, the forks will be parallel to the head stem) .... i.e. the stretch is in the frame, not the trees, and not a combination.
The only HD model where rake is adjusted in the tree, along with the frame, is the VRod
All you proved is your dim-whit status, dimwit!
Old Jun 26, 2007 | 04:52 PM
thrillseeker
ORIGINAL: Cynic
[blockquote]quote:
ORIGINAL: Cynic
[/blockquote]
whatever
VRod
How about this?
full face plant in front of his peers.... thats rich.
This has been a debate for some time now, and with the exception of the '06/'07 lineup, I feel it still is. If I take a position that is corrected, I have no problem addmitting I was incorrect and moving on.
You on the other hand, provided nothing but attitude and immaturity to the conversation. At no time did I take attitude with any statements being made here. I may have disagreed, but if you look at my reply to WS06 you will see that I accept that I was incorrect (for '06/07 at least).
If you are incapable of having a mature discussion where mulitiple parties may disagree, without being offensive, then I suggest you go somewhere else.
And yes, WS06 did back up his statement - what about you? At the moment the only thing you are backing up is that you are a complete a$$hole.
Old Jun 26, 2007 | 06:32 PM
Cynic's Avatar
Cynic
can any1 help i have a 06 lowrider and i am going to put a wideglide front end on with 3degree trees and a 21 inch front wheel i also want to lower my whole bike so it is a level and my question is what size front end should i buy thank you
The first poststarting this thread...... What part of 06 lowrider don't you understand dip-****?
You babies always try to change the subject when you get caught peeing your pants![align=right][/align]
Old Jun 26, 2007 | 06:53 PM
thrillseeker
OMFG - what the hell is your issue? I didn't change any subject. The subject of tree rake came up. I disagreed, and was corrected with actual evidence, and I conceded.
I didn't bring up the topic of tree rake, the discussion drifted there as a part of the suggested solution to the OP.
have you ever had a disagreement with someone where you don't start using insults to back up your position? you are a whopping 54 posts into your membership here and already revealing yourself as a trouble maker.
