front end
Old Jun 23, 2007 | 04:09 PM
06 lowrider's Avatar
06 lowrider
Default front end
can any1 help i have a 06 lowrider and i am going to put a wideglide front end on with 3degree trees and a 21 inch front wheel i also want to lower my whole bike so it is a level and my question is what size front end should i buy thank you
Old Jun 23, 2007 | 04:12 PM
Naz_Man's Avatar
Naz_Man
Default RE: front end
Wide glide trees with 49mm tubes! Go big & fat.
Old Jun 23, 2007 | 04:25 PM
06 lowrider
how long should the set up be stock, over , or under
Old Jun 23, 2007 | 04:48 PM
06 lowrider
is there a way to tell how to make everything even and low
Old Jun 23, 2007 | 04:56 PM
WS6 Formula's Avatar
WS6 Formula
Have you looked into just using the Wide Glide triple trees? They aretwo degreesrake, and usingyour stock tubes and stock rear shocks makes it pretty low and level.
Old Jun 23, 2007 | 05:14 PM
06 lowrider
i was going to buy a new front end so it would be all chrome so i should try to get it stock lenght ?cause i have a 19 inch wheel and going to go with a 21 inch so that moves my axle height 1 inch . so with a sock front and that would end up being higher. i think .... plus the 3 dergee trees would also make it higher so i feel lost !!!!
Old Jun 23, 2007 | 05:40 PM
WS6 Formula
Axle height would only go up about a half inch with the 21" lower profile tire. Also the more you rake it out the lower it will drop, as well as more unstable at speed (high speed wobble).The Low Rider is pretty low to begin with, if you go lower then you get into scrapping pipes, foot controls, and the rear primary case.
Old Jun 23, 2007 | 06:03 PM
06 lowrider
thank you ws6
Old Jun 23, 2007 | 06:08 PM
VenturaChop's Avatar
VenturaChop
can you use the 19 in front wheel on wide glide trees??
Old Jun 23, 2007 | 06:42 PM
Mascman's Avatar
Mascman
Where did you find 3° trees at?
I wasn't aware that they made any for our 2006s.
Give us a link.
