2011 FXDB is now a flame thrower
Old May 11, 2018 | 01:16 PM
Bonkerman666's Avatar
Bonkerman666
6th Gear
Default 2011 FXDB is now a flame thrower
Hi guys. Please view my video. After you’re done laughing, can anyone explain what the hell is going on. Plus it’s only firing on the rear cylinder although both are sparking. New battery and crank position sensor. Cleared a p1001 from my fuelpak 3. Top end rebuild but both pistons an all push rods move and valves open. I’m at a loss.
Cheers and beers
Chris.
Old May 11, 2018 | 02:01 PM
Dutch66's Avatar
Dutch66
Looks like timing is off. Perhaps the pushrods are swapt in the build
Old May 11, 2018 | 02:47 PM
Bonkerman666
6th Gear
mhmm. I put the black on exhaust side and silver on intake. I didn’t think they were cylinder specific. If that’s the case, it would seem an easy fix to swap them over. I did keep them in pairs when I took them out. What do you think?
Old May 11, 2018 | 03:43 PM
Dutch66's Avatar
Dutch66
I do not know wich color the push rods have. But there is a length difference. It is a while ago heen I took them apart. And the last couple of years I use the adjustable ones from Fuelmoto. But this info should be found here on the forum. And sinds it is one cilinder that not work properly, my gues is that the front cilinder pushrods are switcht. Just remove the pushrodcovers and check it out.
Old May 11, 2018 | 03:51 PM
Bonkerman666
6th Gear
good call and thanks. Looks like I have a busy weekend ahead. 👊🏽🤘🏽👍🏽
Old May 12, 2018 | 04:45 AM
Bonkerman666
6th Gear
hey Dutch66. Unfortunately or fortunately as the case may be, the pushrods are in the correct order. What else could throw the timing so bad? I didn’t open the cam cover at any stage during the rebuild. Would it be worth stripping the front rocker box to see what’s going on... and what would I be looking for?
cheers
chris.
Old May 12, 2018 | 06:53 AM
Dutch66's Avatar
Dutch66
It is hard to say from a distannce. I would start with a compression check. Then a spark check ( with a spark tester to see if there is enough spark to jump. Check if the sparkpug wires are nog swapped at the coil. If this all would nog help, you need to open the rockerboxes and check if its in there. If not, pull the pushrods si you can check the lifters. If its not all that then the next step Will be opening the camchest. Good luck and hopefully it is somethinh minor.
Smokey12
Engine Mechanical Topics
11
Dec 29, 2018 09:15 PM
maxburner
Audio Systems
May 18, 2018 11:07 AM
brandontanpg
Welcome Area Only
25
Apr 11, 2018 02:56 PM
bazam9s
Exhaust System Topics
Jan 14, 2009 06:23 PM
