Sputhe chassis stabilizers?
Old May 11, 2018 | 04:44 PM
adamsrotors's Avatar
adamsrotors
Default Sputhe chassis stabilizers?
I'm running Chopper Hauss front and rear motor mounts.
is it worth also running these stabilizers? anyone with experience with them and/or this combination?
would love some photos of the install if possible...they haven't been helpful in showing me how/where they install on a actual bike.
Old May 11, 2018 | 08:31 PM
F86's Avatar
F86
I don't believe the Sputhe stabilizers can be used with anything other than OEM mounts, front or rear.
Old May 11, 2018 | 09:14 PM
adamsrotors
^ they assured me otherwise.
Old May 11, 2018 | 10:40 PM
fxrnutt's Avatar
fxrnutt
They mount to the stock mounts. I've been running front and rear sputhe for about 3 1/2 years
Old May 11, 2018 | 10:41 PM
adamsrotors
and? how do you like them? what motormounts?
Old May 11, 2018 | 10:42 PM
fxrnutt's Avatar
fxrnutt
Whose they? Allen sputhe is dead
Old May 11, 2018 | 10:44 PM
fxrnutt's Avatar
fxrnutt
They're great ... I bought them from the man himself at his shop outside Grass Valley. I'm using the stock motor mounts
Old May 12, 2018 | 09:37 AM
CJD197's Avatar
CJD197
If you drive your bike fast in corners the stabilizers bring the Dyna's to life. They are solid with no sloppiness, so you gain confidence to lay it over enough to start dragging parts if you're not careful.
If you are an average bike driver, who never presses the curves that little bit more every time you go through them...then you will not notice any difference with the stabilizers.
Old May 12, 2018 | 02:31 PM
misfitJason's Avatar
misfitJason
The sputhe and true track will not work with the big bear or chopperhaus mounts. 100%
Old May 12, 2018 | 09:06 PM
multihdrdr's Avatar
multihdrdr
"Chopper is in the Haus"
