Thunder-Max Dyna install
Old Jun 26, 2007 | 05:15 PM
Lil Evil's Avatar
Lil Evil
Default RE: Thunder-Max Dyna install
Hi Guys,
I have a question. On the front o2 sensor harness, how did you disconnect it? The rear has a quick disconnect, so no problem, but the front goes into a box with other wires and their is no connector to take the origninal o2 sensor off. Did you just leave it on and tywrap it to the frame or did you open the box and disconnect the harness or what? Thanks for the replys
Todd
Old Jun 26, 2007 | 05:32 PM
Arcane's Avatar
Arcane
Hello LowriderTodd:
There it a quick disconnect, it is in the plastic caddy that sits behind the regulator. Once you disconnect the o2 sensor you can just cap the plug on the sensor wires that leads to the ecm. You may need to loosen or remove the regulator to get to it.
Good luck with it.
Arcane
Old Jun 26, 2007 | 07:25 PM
Jman67's Avatar
Jman67
The disconnect is in the box you speak of. Take the two bolts out and you will see it in there.
Old Jun 26, 2007 | 08:38 PM
ReAnim8or's Avatar
ReAnim8or
4th Gear
Man you guys just threw a monkey wrench into my plans here! I "thought" I was all set to go with a PCIII and the great support from Fuel Moto (having made the decision over FuelPak), and now after reading this and doing a little research, this looks like it is the way to go. Any of you guys with TMAT previously have the PCIII installed, and if so how has this made your life better. Considering the price difference, I need to justify this in my head.
Old Jun 26, 2007 | 10:41 PM
glide05's Avatar
glide05
reanim8tor,
I know that psycho went this path - PCIII then thundermax on his 06 SG.
I know the search is not very good here - but if you look back you should be able to find his thread.
He is a big fan of the Thundermax - if you PM him I'd guess he will get back to you with details, but his posts are very detailed in general, so if you can find his original post, i'm sure the details are there.
i'm thinking of going this route myself, but probably a winter project as my pipes do not have the o2 bungs and would need to be drilled and have some welded in.
good luck
Old Jun 27, 2007 | 01:33 AM
ReAnim8or's Avatar
ReAnim8or
4th Gear
Thanks for the heads up. Arcane was kind enough to PM me with his personal experience and it was very helpful. I'll definitely do a search for Psycho's post. No such thing as too much information. I'll be doing the work in a month or so (just found out my kid needs braces, so I have to wait for my annual bonus now). I'll post again when it's done.
Thanks again,
ReAnim8or
Old Jun 27, 2007 | 02:16 AM
AZ Rider's Avatar
AZ Rider
I am pleased with my PCIII from fuel moto with the map that was included but I'm looking at a second Harley so the T-Max will be considered for this bike. Thanks for the detailed post, Arcane.
Old Jun 27, 2007 | 08:54 PM
Lil Evil's Avatar
Lil Evil
Arcane and Jman,
Thanks for the replies, that's why this forum is so great! Everybody sharing their experiences and knowledge.
Thanks
Todd
Old Jun 28, 2007 | 05:18 AM
BACA MICK's Avatar
BACA MICK
thanks mate
Old Jul 5, 2010 | 02:35 AM
ncbrq's Avatar
ncbrq
I, on the other hand, have had nothing but problems with my T-MAX in my FXDB. Installed it very professionally and everything was working fine for the most part. I set the AFR target to 13.6 on my Stage 1 FXDB with BUB Jug Huggers and an Arlen Ness Big Sucker.
It ran great for a little while, then began to feel sluggish and I started hearing noises. So I decided to make some changes after changing the oil and learning from my mechanic nothing was wrong mechanically.
Ug, well I learned the hard way that the cable I was supplied with sucks and I have to shove it into the T-MAX to get it to sync. (I realized this when the T-MAX would not connect when I went to make the changes. Zippers replaced the cable under warranty, but gave me the wrong one! Why didn't they replace the cable with the same cable I sent them, exactly?)
Anyway, I decided to turn off the AFR target feature this time and rely on one of Zipper's maps. Of course Zippers has no map that's anywhere close to my configuration, so I used the one they recommended. It idled better, but otherwise ran funky. It popped on the decel like crazy! Eventually that went away but when it went away, the bike started running awful. It puts, misfires when I rev from time to time, and won't maintain a single speed without jerking about.
After checking all connections to ensure nothing came loose and monitoring my engine from my computer to see if there was a data feed problem from the sensors (none), I decided to re-install my stock ECU, which has a SERT module dyno tune. I got the T-MAX because I wanted to easily adjust if I got new pipes and because I don't believe I should have to pay $150 or more every time I make a configuration change. Well, the bike runs like normal without the T-MAX... a little lean, but that's because I had quiet baffles in when I did the dyno tune, now I have performance quiet baffles tomorrow.
I'll be contacting T-MAX about this, but, given my luck with companies providing Harley parts and Harley-Davidson itself, I'll get screwed.
