FXDLS HP/TQ Upgrades
Old May 17, 2018 | 09:12 PM
Dyna0352's Avatar
Dyna0352
Default FXDLS HP/TQ Upgrades
I am considering a number of performance upgrades and I want to get some opinions....
I commute to work in the city on my fxdls and I am only able to get out on the open roads on the weekends. That said, I am looking to do a cam upgrade so I can get more torque on the lower end. I am already ruling out Harley’s 117 kit because from what I have read, that engine runs properly at higher consistent rpms, on the open road.
If I am planning on getting cam work done, I am open to going all out with a kit and an oil pump/plate.
What are your recommendations? S&S? Feuling?
I am also curious to us to hear from people who are running Barnett clutches and the difference they see vs stock.
Thanks!
Old May 18, 2018 | 11:53 AM
CryingJoker's Avatar
CryingJoker
I'm running s&s 625 cams in my fxdls. Stock displacement but I've got some head work and high compression pistons in mine. Netted 117 hp/119 torque at the wheel. Well performing cam on the mid to upper range. If you aren't planning on doing other engine work I'd say probably a grind more like a 583 or 585. But my personal outlook.
Old May 18, 2018 | 03:08 PM
martinj's Avatar
martinj
The stock fxdls doesn't have enough compression for the 585 to do well in it. The 583 "might" work ok, but without increased compression, I probably would look for something with an earlier intake close, or consider bumping the compression (to 9.8 or 10:1) with a thinner head gasket and possibly a small cut on the heads.
Old May 19, 2018 | 05:54 AM
Nickd2689's Avatar
Nickd2689
I would disagree with your statement on the 117. I installed mine at 4K, now have 20k and feel it runs just fine at lower speeds/rpms. I had mine tuned and have more power at lower rpm than high and I couldn’t be happier.
marcodarq
Engine Mechanical Topics
30
Sep 5, 2017 05:09 PM
Adam87t2
EVO
Jun 7, 2017 08:18 PM
Puglia10
Mar 10, 2014 07:26 PM
George0620
May 21, 2010 08:54 AM
Psycho
Feb 25, 2007 09:35 PM
