Help me choose a cam.
Old Jan 8, 2007 | 09:29 PM
Psycho's Avatar
Psycho
Default Help me choose a cam.
This all happened kind of fast. Wasn't really planning on it, but I've been keeping my eyes open to do this on the cheap and things just kind of came together. I mean I'm doing this cheaper than dammit.
Anyway, I scored a brand new set of the screamin eagle forged high compression pistons off of ebay, cheaper than dammit. My local machinist will bore my jugs to match them for 35 bucks each. He's done a lot of work for me over the last 15 years, and I trust him completely. I am going to use my stock heads for the 9.6:1 compression ratio to maintain easy starting and driveability, although I will polish the ports while I have them off.
All I have left to buy is a gasket kit, and a set of cams.
So, my question is, which cam?? Somebody tell me what I want for the best driveability, and smooth power build. I don't want to build a high rev horespower monster, I want to build torque fast and scream off the line.
I'm not neccesarily trying to stick with harley parts either. I'll consider any quality brand performance cam.
Help me out here. Any suggestions??
Old Jan 8, 2007 | 11:18 PM
ButtMan1000's Avatar
ButtMan1000
Default RE: Help me choose a cam.
I have Andrews TW-37G's with the S&S Cam Gear Drive.
88 C.I.
Stock heads and intake
Dynojetted CV
SE Stage1 Air Cleaner Kit
SuperTrapp SuperMegs 2:1 exhaust
The 37G's are designed for a 95 C.I. build and a slight compression increase. I am amazed at the currentmotor's performance with the 37's and basically bone stock otherwise. Look at the torque curve on the chart, I cannot complain about the cams at all and look forward to the 98 inch upgrade I will do soon.
My Dyno chart, raw run, no tuning:
[IMG]local://upfiles/20717/CE640F755B2647B982EEB5DFED49A810.jpg[/IMG]
Old Jan 8, 2007 | 11:52 PM
Georgia Rider's Avatar
Georgia Rider
Get American Rider magazine from two months ago--they have an article on a new cam by Andrews made for the 06-07 Dynas--TW37H--does not require gear drive and you can use the same stock pushrods. Cams are set up to dramatically increase torque from 2200-4000rpm. This months issue with the Dyna on the cover has an article on increasing torque on 88's.
Old Jan 9, 2007 | 12:42 AM
mentor70's Avatar
mentor70
If you not planning to mill you heads down a bit then use a .030 head gasket, You will be far short of 9.6 to 1 compression with you stock heads!
My heads are at 78ccs and with a .042 gastket im at 9.8.
Old Jan 9, 2007 | 01:05 AM
Psycho's Avatar
Psycho
Well, I'm currently looking at the 204's and the 211's. Seems to me the shorter duration of the 204's would build more low end torque.
I've also nearly got myself talked into having the heads ported and polished as well.
Somehow I just cannot see any advantage in the 211's with that much duration for building low end torque. Seems like it would kill the low end.
Any thoughts or personal experience??
Old Jan 9, 2007 | 01:37 AM
ButtMan1000
Check out the spec's for the Andrew's 37G's or 37H's, and the 211's.Then look at my dyno chart again. 80 to 88.9ft/lb's of torque form 3,000 to 5,000 RPM.
Just hit "Search" when the link comes up.
http://www.nightrider.com/cgi-bin/ff...?ff_config.txt
Old Jan 9, 2007 | 04:02 AM
mud's Avatar
mud
ORIGINAL: ButtMan1000
ButtMan, what is STD smoothing??
Never heard of that one before. Always SAE.
mud
Old Jan 9, 2007 | 09:10 AM
Psycho's Avatar
Psycho
That 37G does look like a good torque cam with only 26 degrees of overlap.
Old Jan 9, 2007 | 09:24 AM
Psycho's Avatar
Psycho
So what are the idle characteristics of the TW37G??
Old Jan 9, 2007 | 12:20 PM
mentor70's Avatar
mentor70
the 37s are almost like stock, well until you crack the thottle.fairly smoothe.
the 211s are more suited to 95 in bikes with 10.1 compression or more, it would idle like crap on a 88 with stock compression.
You could to a S&S .510 cam too if you wanted a choppy idleand still have a mostly stock motor!
[IMG]local://upfiles/22371/BF108DA8045F4206A5FAEA18F3620370.jpg[/IMG]
