Will not crank
Old Jun 12, 2018 | 06:33 AM
rspoon5615's Avatar
rspoon5615
Stage II
Default Will not crank
2008 heritage softail classic. I flip the switch to run, lights and fuel pump engage. When I press the start button. Nothing happens, not even an attempted crank or sound. I have checked the fuses and took the battery out and charged it.
It was running before I parked it to install a wiring harness for a trailer. The harness has its own fuse to single out the trailer.
I am sure I am missing some easy things to check but not sure for this is my first motorcycle and want to learn and do the maintenance myself.
I appreciate all input. Thank you.
Old Jun 12, 2018 | 10:11 AM
NORTY FLATZ's Avatar
NORTY FLATZ
Ground?
Old Jun 12, 2018 | 09:15 PM
crusader1xxx's Avatar
crusader1xxx
How is the battery? Just cause you charged it doesn’t mean it is holding a charge, when dealing with electrical problems first step is making sure the battery is working properly. Then ground wires, then tracing the wires to which ever component is not working....
Old Jun 12, 2018 | 09:16 PM
crusader1xxx
Get your battery properly tested at a place that knows how to do it....
bowhunter97
2014-2024 Touring Models
95
Feb 7, 2021 07:34 PM
JoshFG
Jan 30, 2018 10:12 AM
Rocketman69
Dec 2, 2012 09:02 AM
icepick
Mar 10, 2012 11:32 AM
variablek
Mar 31, 2009 09:02 AM
