Turn signal bulb
Old Jun 15, 2018 | 07:57 PM
Doug W's Avatar
Doug W
Default Turn signal bulb
Okay; how come a replacement bulb from the local hardware store that is the proper voltage, looks exactly the same physically, is rated very near the candle power of the original bulb, and fits into the socket properly, NOT work in my 2016 Wide Glide??
Old Jun 16, 2018 | 04:23 AM
Bone Doc's Avatar
Bone Doc
Be explicit. When you say it doesn't work do you mean it won't illuminate or won't flash?
Is it a front turn signal or a rear turn signal because they are different? Front turn signals are running lights as well and require a dual filament bulb. Rear turn signals are not running lights and use a single filament bulb. Given the information you provided, although the bulbs may look the same, I'll bet you purchased a single filament bulb when you needed a dual filament bulb. It is a common mistake.
Old Jun 16, 2018 | 05:25 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Even if it worked, it would not work long. Go to the Harley store and get their heavy duty bulb 68168-89A (I think). Probably still made in China but they spent .02 cents more making it last longer. I know, it's $5.00 but they are two
Old Jun 16, 2018 | 05:27 AM
Flinter's Avatar
Flinter
I've tried using bulbs from the auto parts store (1157) but every time I did they bubbled the plastic lenses on the turn signal.
Bulbs from Harley don't.
Old Jun 16, 2018 | 09:17 AM
Doug W's Avatar
Doug W
Well, this is strange; and yes, I wasn't being very specific. Sorry!
It is my right rear turn signal. Both filaments burned out.
All four of my original turn signal bulbs are dual filament, and all four function as running lights (on all the time) as well as turn signals. And yes, my owners manual only mentions the front bulbs as being running lights.
The replacement bulbs I tried, as well as the original bulbs, are all 32/3 candlepower. It's obvious when signaling, that the 3 candlepower is the running light and the 32 is the turn signal.
I'll likely end up making a run to the nearest dealership; but first (and perhaps as a temporary fix) this morning I plan to try a bulb from an auto parts store.
Old Jun 16, 2018 | 10:57 AM
Doug W's Avatar
Doug W
Bought a pair of Sylvania bulbs, and they work great.
In turn-signal mode, they're lower in candlepower than the originals (21 in place of 32). In running-light mode, a bit higher (4 in place of 3), but they'll be fine until I get a chance to stop at the Harley store.
No idea why the rears are also functioning as running lights; I guess that will remain a mystery for now..
Old Jun 16, 2018 | 12:42 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Does the '16 WG have a tail light, some models used the rear turn signals as a taillight/brake light/turn signal.
Old Jun 16, 2018 | 01:15 PM
Doug W's Avatar
Doug W
No tail light.
JerryDinMD
Feb 19, 2014 03:51 PM
BlackPearl#1
Sep 25, 2012 08:02 AM
kzoo
Sep 13, 2011 08:01 AM
homyakchik
Mar 10, 2009 03:14 PM
outdoorgirl57
Jul 20, 2007 03:25 PM
