Performance Machine Brake rotor. Good or bad
Im thinking about buying a brembo .484 radial mount brake caliper and a axial to radial brake bracket from Speed Merchants. Or just buy a Brembo .484 axial brake caliper. My question is, are the PM rotors good and I should stay with the one on the dyna. Or is the PM rotors one of the issues along with the PM 6 piston caliper which doesnt have great reviews and a stock harley caliper is better. I should have done my research back in 2014. I can go with one of these routes
1) Leave PM rotor if maybe its only the PM caliper. Install .484 Brembo axial caliper
2) Leave PM rotor, install axial to radial bracket and get a .484 Brembo radial caliper
3) Get the Arlen Ness 15 inch big brake rotor with a .484 Brembo radial caliper
4) Get a 11.8 Lyndall front rotor (rear rotor is hidden by leather pros bags) axial to radial bracket and .484 brembo radial caliper
5) Get a 11.8 Lyndall front rotor and a a .484 brembo axial caliper.
If your PM rotor is stock size, you might just try a return to the original caliper, but with an upgraded pad and fresh fluid. And a braided line will help with feel, if not actual braking power. I'm sure there's a way to achieve strong braking with PM calipers, but I've really come to think of them more as styling bling than as a performance upgrade.
You have an S1000R AND an S1000RR??? Geez... and a Panigale? You're right... You'll never actually be THRILLED with your HD braking performance!
Would you say that the 13 inch PM floating rotor is better than the Lyndall? I would love have a matching rotor for my wheels and chose the Lyndall 11 spoke chrome because it was the closest to my hooligan wheels. Regarding the brake calipers, my brother from my MC is a dealer for Brembo so Im getting the calipers , whatever calipers I decide on and whatever rotors I decide on at cost. When he spoke to Brembo he was told the .484 radial left calipers were on back order for almost a year. But they have the .484 radial caliper left and right kit in stock. We have another MC brother who wants to go the same route as me with the .484 radial and Brembo told my MC dealer brother that they have a customer who needs 3 108mm .484 radial calipers. So they may break up 3 kits. Sell one dealer 3 right .484 radial calipers and sell our MC brother 2 .484 left radial calipers. However now my bro was looking at the nickel plated 108mm Brembo GP4RX radial caliper. He liked it because it was nickle plated, better braking and we could get a chrome speed merchant axial to radial caliper mount to match our chrome wheels. After my dealer bros discount the price difference between the 108mm .484 radial and GP4RX108mm is only $56. And the chrome axial to radial mount brackets are less expensive than the anodized black ones. There isnt a huge price difference between the chrome and black... about $5. Thats how we are able to upgrade all our parts at dealer cost. Having a MC bro as a dealer we get everything at cost so I can upgrade my Streetglide, dyna, both BMWs and Ducati. And he benefits from us as contractors, plumbers, electricians, ophthalmic eye surgery field and other areas.
But Id love to hear your input and recommendation on whether to get a 13 inch floating PM rotor (hooligan style to match my wheels) with the brembo radial calipers. Or a Lyndall 11.8 chrome rotor? Would love to get your feed back. And if you dont mind a good response on your 13 inch floating rotor.
PM aren't Willwood or Brembo but, all things being equal, it still should be better than the stock caliper.
If it's worse, it might be an issue with bleeding the system, mixing brake fluid (DOT4vDOT5), dodgy brakeline, or the discs themselves might be glazed, over-worn etc. Also the master piston might be leaking (if they are not maintained, water can eventually enter the system and corrode the piston, allowing fluid to squeeze past and making it feel spongy and horrible. (Sorry if this is all stuff you already know or have worked through
)Even with all that done, one disc is just not enough to give really good braking (And I'd include even an awesome single Brembo setup here). These bikes are just too damned heavy.
It's adequate, and safe enough (I have a single AN BigBrake, EBC H-H pads and a braided line, and it does the job. But, it's nothing like my old Ducati or even my old BMW Airhead (a single 4 Piston Brembo).
Twin setups are definitely the go, but by then then you will have come up against tire traction, crappy suspension and other brake-related limitations..
