2003 Low Rider Rattle
Old Jul 25, 2018 | 07:37 PM
TheFreakyTiki's Avatar
TheFreakyTiki
Stage II
Default 2003 Low Rider Rattle
Hey all,
So I've been trying to pinpoint a rattle coming from what seems like the front end of my 2003 Dyna Low Rider for the past month. I've changed the motor mount but that wasn't the culprit. I also tightened down the gas tank but that didn't help either. When I have the bike on the kickstand everything is fine but when its up it sounds like shaking a spray can. Also when going over bumps I get a loud clank in the front end as well. Has anyone else had this issue?
Old Jul 25, 2018 | 08:00 PM
nashspu's Avatar
nashspu
I had a rattle that I couldn't find and it turned out to be a broken exhaust bracket on the back and my heat shields cracked and vibrated until one fell off.
Old Jul 25, 2018 | 08:44 PM
nevil's Avatar
nevil
Check the rubber bumper on the kickstand. Sometimes all you need to do is rotate it to a different position. Something in the exhaust system was another guess, too.
Old Jul 25, 2018 | 09:11 PM
Tall Timber's Avatar
Tall Timber
This would be my first culprit as well.
Second would be give your horn cowbell a rattle, the horn has been known to come away and clatter around in there.
Old Jul 26, 2018 | 12:54 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Had this rattle/clunk going over some speed bumps or road imperfections while in Daytona one year on my 2002 FXD and what I found was the steering neck bearing. What I did was loosen the pinch bolts on the lower tree, tap in the clamps with some thing that won't mar the metal. I used a piece of 2x4, then I snugged up on the steering head bolt. Tighten up the lower tree bolts and no more clunk. The lower bolts need to be loose to allow the slightest movement of the forks while the bolt is snugged down. Good luck
Old Jul 26, 2018 | 03:51 PM
Monteman1971's Avatar
Monteman1971
I had something similar, turned out to be the pop rivets that hold the headlight bucket to the mount were not crimped tight. I replaced the rivets with nuts and bolts and was good after that.
Steve
Jesus Gabriel Acosta
Jun 13, 2019 10:00 AM
fourtrx27
Jul 25, 2011 12:33 PM
clc3251
Nov 24, 2010 10:26 AM
CarlSpackler
Mar 10, 2009 11:16 PM
pauletich
General Topics/Tech Tips
May 31, 2006 08:34 AM
