Issues with my Low Rider horn
Old Jun 12, 2019 | 04:13 PM
Jesus Gabriel Acosta's Avatar
Stage III
Question Issues with my Low Rider horn
Hi
My Low Rider 2015 horn failed. But there is error code: b2129 "Horn Output Overloaded". Mechanic in dealer told me I have to buy a new BCM. But the only thing which is wrong is the horn. Who knows what else I can do?
Old Jun 12, 2019 | 04:21 PM
Jay Guild's Avatar
Jay Guild
Jesus, we usually go with some kind of introduction for a first post. Second, do you mean ECM, not BCM?
Old Jun 12, 2019 | 04:32 PM
HyperM3's Avatar
HyperM3
Does Jesus actually need an introduction?.....
Old Jun 12, 2019 | 04:49 PM
Stage III
Oh, my apologize.
My name is Jesus. I ride a Low Rider 2015. Im from Colombia. I live in Medellín.
Nope. The problem is the BCM (Body Control Module)
Old Jun 13, 2019 | 09:52 AM
Jay Guild's Avatar
Jay Guild
It depends on how it failed. Does it work at all? You may just need to clean the terminals, the connectors, and the ground connection under the seat. After you try all that see if the horn works. You can try to replace the horn. I can give you all kinds of possibilities but I can't tell you what will fix it without more information other than it doesn't work and the error code. The error code indicates there is more impedance on the wiring or in the horn than is supposed to be there but there is still a full positive and negative connection.
Old Jun 13, 2019 | 09:57 AM
Jay Guild's Avatar
Jay Guild
If you have a multi-meter you can check the voltage at the horn connection when it is pressed as well.
Old Jun 13, 2019 | 10:00 AM
Stage III
Hi
Thank you for your answer. I bought a new horn. And the situation didn't chance. I deny for the moment to buy a new BCM jus fot de horn. I cleaned terminals and the conecctors as you suggested to me. I will see today how is going on in my everyday ride.
Again, thanks a lot for your answer.
jcanrun
Jul 20, 2018 02:36 PM
harlot
Mar 22, 2016 07:17 AM
Iron obsessed
Mar 20, 2015 08:15 AM
Strgzr
Aug 16, 2008 06:03 AM
HDF Tech
General Topics/Tech Tips
Nov 1, 2005 08:40 PM
