Preadator mount vs. True-Track mount which one should I get???
Old Sep 21, 2018 | 01:13 PM
  #31
rossWG's Avatar
rossWG
this is an interesting thread for me,
i can't help thinking though, it would be more interesting, if the riding styles were also added with some of the good points and opinions being offered
my bike is 18 month old, with over 15k miles on it, and another expected 2k in the next few weeks. i just cruise in the main, but get a lot of vibration fatigue thru the pedals. am i wasting money on this course of action
Old Sep 21, 2018 | 05:17 PM
  #32
k-weaver's Avatar
k-weaver
Originally Posted by John CC
When I first got this bike, one of my initial impressions wat that it had more vibration than it should. Being a Harley neophyte, I figured it was just the way it was. Then, I started reading about shimming the front motor mount. (500 or so posts...) So, I went through the process of supporting the engine and checking the gap. To my surprise, there was what appears to be a professionally made shim in there already. It's about .060 thick. I'm thinking the bike could use about that much more, but left it alone. Then, I discovered the "bump" issue. Back I went, to discover that the mount was collapsed and the engine bracket was sitting hard on the hump. Man, that stuff is hard to file... Anyhow, that netted me a noticeable improvement.
So, I really think I should replace the mount. Given it's bad, I probably ought to replace the back one, too. So, as I see it, I have the following options:
  • First, I can replace both mounts with OEM parts for a total cost of about $200.
  • Second, I could go with the Predator front mount and a factory rear mount for about $350.
  • Third, I could go with the Predator in front, a new rear mount and a Sputhe stabilizer, if they'll sell me the rear half, for about $540
  • Lastly, I could try to get the rear half of the True Track setup, with the Predator, for about $550.
I've excluded the True Track in front as I have an oil cooler there and have heard that they are not compatible.
I suppose another possibility is a stock front mount with a rear mount and stabilizer, but it seems the front mount is the problematic one, so I'm thinking that doesn't make too much sense. Or, I could completely cheap out and just change the front mount.
Sorry for the rambling post. What do you all think? What about a non-OEM rear mount?
TT works with an oil cooler. dont believe everything you read on the internet.
Old Sep 22, 2018 | 12:37 AM
  #33
JayStronghawk's Avatar
JayStronghawk
Thumbs up
Consider the Predator Front Mount one of my better Mods .. Noticed the Difference as soon as took off on it ..
Old Sep 22, 2018 | 08:40 AM
  #34
John CC's Avatar
John CC
OK, so there's another possibility. True Track plus new OEM mounts is the most expensive option, though. Are you sure it will fit with the Jagg cooler? There's a lot going on right in front of the mount.
Right now I'm leaning towards the Predator for the front as it is the only option that eliminates the OEM front mount.
Old Sep 23, 2018 | 12:21 PM
  #35
rossWG's Avatar
rossWG
is the predator, just a bolt on install? no adjustment necessary
Old Sep 23, 2018 | 05:08 PM
  #36
k-weaver's Avatar
k-weaver
Am I sure? Well it seem to fit just fine when I installed one on my bike...
Old Sep 23, 2018 | 05:09 PM
  #37
k-weaver's Avatar
k-weaver
Its a bolt on install although I'd always check motor alignment after swapping a motor mount.
Old Sep 23, 2018 | 05:57 PM
  #38
rossWG's Avatar
rossWG
Is that the rear wheel alignment check?
Old Sep 23, 2018 | 07:35 PM
  #39
John CC's Avatar
John CC
Interesting. Maybe it's just the angle of the photo, but that doesn't look the same as mine. Where is the bracket for the oil cooler?
Old Sep 24, 2018 | 10:28 AM
  #40
k-weaver's Avatar
k-weaver
Everything is stacked up on the two bolts to the motor mount. So the bracket is angled to stick out a bit and I had to pull it out a tad bit more to get it to fit. It goes like this though:
Oil cooler bracket -> TT -> Frame -> Motor
I had my TT installed by the guys at TT. I asked the question of will an oil cooler fit during install and I was told it would fit no problem. I picked one up a few months later and didn't have any issues. If you are concerned, I'd say give them a call. They are super nice guys.
