Engine Mount Confusion
Old Aug 17, 2018 | 11:18 AM
gleam's Avatar
gleam
I wonder if this lateral movement is what I'm feeling. I haven't had the chance to really ride my fat bob much yet, but a few times when I was on a good, mildly aggressive line with it, I felt something happen with the back tire. It felt like the rear tire was suddenly on its own line, wider than mine. I didn't feel it hop or skid or anything, it just sorta feels like it slips into a wider line on its own.
Then again my tires are getting down there in tread, about 3/4 of the way to a change so it could be that as well. Doesn't feel like it though. Feels like the floor coming out from under you.
Old Aug 17, 2018 | 11:41 AM
Huggerbugger's Avatar
Huggerbugger
I have often wondered why my rear fender vibrates back and forth when idling. This is why. Seems engine alignment and rear tire alignment are not independent.
Old Aug 17, 2018 | 01:40 PM
WS6 Formula's Avatar
WS6 Formula
Originally Posted by WS6 Formula
Actually the engine, transmission, and swing arm are bolted together as one assembly that is rubber mounted into the frame. So adjusting the top Heim joint is used to move the assembly to align it with the front rotor/wheel.
I used a magnetic digital protractor attached to the front rotor, zeroed it out, then attached it to the rear rotor and adjusted the top Heim joint.
Old Aug 17, 2018 | 03:53 PM
cggorman's Avatar
cggorman
Yes and no. The rear tire alignment can vary quite significantly due to spacer setup, axle adjuster (HUGE factor that's often glossed over. You can easily get +/- 5 degrees or more here.), and swingarm pivot slop...not to mention swingarm geometry itself (bent, warped, poorly jigged during welding, etc)
Old Aug 17, 2018 | 04:31 PM
Campy Roadie's Avatar
Campy Roadie
I guess I'm just not comprehending the design philosophy. Even my expert Indy did a double-take when he first saw it. Why would you attach the engine to the swing-arm?
You pay an independent motorcycle mechanic to work on your Dyna that didn't know a Dyna swing arm pivot shaft runs thru the transmission case and not the frame? Find another mechanic.
Old Aug 17, 2018 | 07:40 PM
Huggerbugger
His specialty is sport bikes. No one wants to work on Harleys.
Old Aug 17, 2018 | 08:54 PM
crusader1xxx's Avatar
crusader1xxx
Anyone else from San Diego want to help this guy out and point him to a good HARLEY Indy shop....
Old Aug 17, 2018 | 09:16 PM
Reindeer's Avatar
Reindeer
I do. But only my own.
Old Aug 17, 2018 | 11:12 PM
EasyLiving's Avatar
EasyLiving
This guy is the biggest troll on the Dyna forums. Why do people even read and respond to this stuff?
Old Aug 18, 2018 | 10:32 AM
archergodwin's Avatar
archergodwin
Yep, hard to find an indy that knows how to work on Harley's.... which is weird, because I think my Dyna is one of the easiest bikes I've ever worked on.
That said, I do all my own work.
