Engine Mount Confusion
Old Aug 16, 2018 | 06:21 PM
Huggerbugger's Avatar
Huggerbugger
Default Engine Mount Confusion
The rear of the engine (via the trans) mounts to the pivot arm. Why the rear isolator?
Old Aug 16, 2018 | 07:19 PM
Reindeer's Avatar
Reindeer
It's gotta attach to the frame somehow...maybe I don't understand your question.
Old Aug 16, 2018 | 07:32 PM
Huggerbugger
It attaches to the frame via the transmission. The rear isolator doesn't support the engine like the front isolator does.
Old Aug 16, 2018 | 08:41 PM
O-Town D's Avatar
O-Town D
The swingarm is attached to the tranny case as you noted. The isolator is attached to the back of the tranny case and to a plate that is welded between the Dyna's rear "downtubes."
Old Aug 16, 2018 | 08:44 PM
Huggerbugger
Exactly. I don't understand the design concept. Essentially, the rear of the engine is hard-mounted. Why the isolator?
Old Aug 16, 2018 | 08:54 PM
crusader1xxx's Avatar
crusader1xxx
Actually it doesn’t, go back and read a few of tincupchalice’s posts on the subject. The swing arm is connected to the transmission, it doesn’t touch the frame.
The only connection to the frame is the top shock mounts.
Think in in terms of sections. The frame is one section and the power train another...
The frame includes the front forks, front wheel, gas tank, rear struts & rear fender and all that is attached.
The power train would be the motor, transmission & rear swing arm and everything attached to those items including the exhaust.
The reason for the rear rubber mount, is to help the power train. If it was ridged it would be breaking transmission cases.
The reason the FXR handled so much better was that the swingarm was part of the frame, not the power train....
Old Aug 16, 2018 | 09:59 PM
Huggerbugger
Went out and looked at it again. I see that the swingarm pivot bar is only attached to the transmission and not welded to the rear downtubes. Hmmmm. So the connection to the frame at the rear of the engine is the isolator. Hmmmm.
Old Aug 16, 2018 | 10:07 PM
F86's Avatar
F86
Bingo.
And hence: Alignment... Stabilizer... etc.
Old Aug 17, 2018 | 10:13 AM
cggorman's Avatar
cggorman
Yup. Not a great performance solution. Kinda like building a house on a foundation made of gelatin. They tried to limit lateral movement with the design of the isolators but it's less than ideal.
Old Aug 17, 2018 | 11:17 AM
Huggerbugger
I guess I'm just not comprehending the design philosophy. Even my expert Indy did a double-take when he first saw it. Why would you attach the engine to the swing-arm?
