Vibration & Alignment: At Odds?
Old Sep 4, 2018 | 04:32 PM
F86's Avatar
F86
Originally Posted by crusader1xxx
I believe your process is correct but I think you need to do the whole alignment procedure with both mounts loose...by taking off the top link, it might have disturbed the alignment which was only held by the rear mount as the front one was loose.
Usually I do it without ever removing the top link, but since that's what I was changing this time... I honestly don't recall if the top link was under tension or not last time I aligned things...
i think if you do it again w/ both mounts loose then the top I’d adjusted it will be good....
It's really fine now... I've aligned my bike pretty thoroughly on a number of occasions, and it handles very well. It just struck me this time that the point of optimal rear wheel vertical alignment may not necessarily be the same as the drivetrain position that yields the least vibration.
Old Sep 4, 2018 | 08:13 PM
misfitJason's Avatar
misfitJason
Yes this. Both mounts loose at the same time.
F86
Nov 19, 2020 01:22 PM
nbowen805
Feb 8, 2018 10:43 PM
natural gasser
EVO
Jul 16, 2017 10:03 AM
JohnnyRebKY
Jun 10, 2014 11:47 AM
Heathen
May 2, 2009 11:23 PM
