Adjust front forks
Old Sep 26, 2018 | 05:34 PM
blingin96's Avatar
blingin96
Stage II
Default Adjust front forks
2002 DYNA FXDL
Just had my shocks rebuilt with new seals and new progressive springs.
The TOP of the forks have no adjustments.
ARE there ANY adjustments I can make?
Old Sep 26, 2018 | 05:37 PM
blingin96's Avatar
blingin96
Stage II
I removed them had them rebuilt and then I reinstalled them. I did see some type of adjustment on the base of the forks near the front axle.
What exactly is that for?
Old Sep 26, 2018 | 06:00 PM
cggorman's Avatar
cggorman
Probably the drain plugs. I believe the FXDX models were the only TC88s with adjustable fronts.
Old Sep 26, 2018 | 08:01 PM
tcazes's Avatar
tcazes
the only thing you can adjust is preload. you would have to pull the caps off and start trying to adjust it for yourself. i can say this though.....i hope you talked to progressive first to make sure they are setup for you..... basically its not like legends cartridges that you can adjust preload etc. you will have to cut the spacers to figure it out yourself.
rwven
2014-2024 Touring Models
14
Oct 9, 2020 10:22 PM
truckerdave
Oct 29, 2011 01:26 PM
SgtMic
Jan 26, 2010 08:19 PM
95hdtlk
EVO
Jul 20, 2008 10:28 AM
js1268
Oct 24, 2007 06:23 PM
