FXDX fork springs?
Old Oct 27, 2011 | 12:57 PM
truckerdave's Avatar
truckerdave
senior experienced all-knowing leader of the unwise
Default FXDX fork springs?
Got to replace both slightly bent fork legs from where i went airborne(flying was no problem, landing upside down was) and thought i might do a little work on them while i had them apart. Just wondering if anyone had ever used the patriot suspension FXDX progressive rate springs? I ordered some off ebay($60) thinking they might cure the only slight problem i ever had with the forks. Under really hard braking they dove pretty bad, you could adjust it out with the preload adjuster and compression damping but then it rode harsh going in a straight line. For those who don't know what i am talking about FXDX forks are 39MM 3 way adjustable cartridge forks. You can set them up to where they ride better than touring bike forks but you get the dive when they are adjusted that way. I just wanted to have my cake and eat it too.
Old Oct 28, 2011 | 08:06 PM
Dyna_in_the_works's Avatar
Dyna_in_the_works
Had mine apart this winter for the same reason, they were pretty spongey. Looked into trying to replace the internals but after much effort and refusing to pay for a whole new drop in cartridge system I just went with the fxdl front forks, as I had already purchased progressive rear shocks. Harley went away from the cartridge style for because it was difficult to manufacture and didn't offer much more really than the true spring front ends. This is what I was told by the HD mechanic, a good friend of my engine builder.
So make sure that your issue while breaking isn't something more serious. Take them entirely apart and have them inspected, that is my advice. You mat save alot of money by converting to an fdxl front end, its a direct swap 39mm front end.
Keep us posted on your progress.
Old Oct 28, 2011 | 10:42 PM
parts eeter's Avatar
parts eeter
Thats the first time I ever heard of the fully adjustable, dual disc brake 39mm front end being inferior to the damper rod basic forks that are spec on almost everything else HD sell.
In general I have never bought any motorcycle that didnt need the valving setup for me, proper springs, and tinkering with several different fork oil weights and heights to get a machine dialed in perfectly.
That being said the FXDX forks were the most adjustable and versatile forks to come on the Dyna. Granted a set of Ohlins modded 49mm forks are superior to the 39mm FXDX forks due to top shelf components used along with the larger more rigid 49mm tubes, but that setup will end up costing you another 2 grand on top of having to buy better shocks as well and dual discs for the front brakes.
To the original poster of this thread. I recently did some research and for my 255lb self, I need 1.05Kg fork springs. I will start off with a 10wt fork fluid setup at OEM recommended height and will tune from there.
Springs are readily available up to .95kg from Race Tech but since I need heavier springs than they have I will probably have Cannon Racecraft make me a set of 1.05 KG springs custom ordered.
Maybe Dyna in the works will sell you his old fork legs?
Something to be considered is a more heavy duty spring say on the high end of your required spring rate along with a lighter wt oil set with a little more oil height will net a softer initial ride with greater resistance to dive in harsh conditions. Personally those one size fits it all springs will never fit the bill and I would ditch those for a set thats meant for your weight.
Old Oct 29, 2011 | 05:31 AM
truckerdave
The stock springs were perfect(except for dive) and can be adjusted for preload of course. The initial spring rate is not that important unless it is too heavy and i believe the new springs should be the stock weight. I could set it where i could hit bumps and not even feel them while the guys on touring bikes were bouncing off their seats but then i got dive under hard braking(dual floating rotors and better pads). I believe i am right with the progressive rate springs. I actually had a FXD front end with progressive springs on it before and it was vastly inferior to the FXDX forks but the FXD forks did not dive excessively. You have to understand how to set the FXDX forks up to get them to work right. Anyone who thinks FXDL forks are better should ride beside a properly set up FXDX and watch the suspension work. They are long travel forks and the legs are 1" longer than regular FXD forks. The 04-05 forks like i have had a 1" axle and with the addition of fork brace there was no flex whatever. I consider these to be the ultimate Dyna forks. Sure hated to wreck it and bend the forks! When i finish rebuilding the forks and installing the new springs i will give ride report.
Old Oct 29, 2011 | 09:53 AM
parts eeter
My main problem with the stock springs on the FXDX is that even with the preload cranked down to the max I still have 2 inches of loaded sag. I prefer 1 inch loaded sag.
Be sure and post your sag/ fluid weight, and fluid height choices along with a comparison once yours is completed.
I think buying a one size fits all spring is kind of taking a shot in the dark with a blindfold on, but thats just me and my opinion. That is probably because I spent years racing MX and usually the first thing I would do to my bikes would be bring them home, disassemble and grease the bearings and install the proper rate springs for my weight. You know old habits are hard to break......
On a side note I have a buddy that has a great machine shop and I am gonna ask him to make me some high rise Mid Control Brackets out of billet aluminum to save about 5 lbs and add cornering clearance. I still have to do measurements and will adjust height accordingly.
Every little bit of weight reduction and cornering clearance you can get on these bikes makes a difference. Hence, the reason I only want 1 inch loaded sag.
Old Oct 29, 2011 | 01:26 PM
truckerdave
My springs were heavier than that. On the soft preload setting i had about 3/4-1" sag and i weigh over 200 lb. Same for the rear FXDX shocks. These were new forks that i bought from Harley a couple years ago for the 04-05 models.
FXSE17
Mar 10, 2018 10:37 PM
LA_Dog
Dec 20, 2015 07:27 PM
ADRENALINE RUSH
Apr 24, 2015 05:33 PM
p51bombay
2014-2024 Touring Models
Aug 31, 2014 07:24 PM
SlowRebel
EVO
14
Nov 30, 2011 08:26 PM
