Battery change
Old Sep 27, 2018 | 10:33 AM
Southcoastsoulboy's Avatar
Southcoastsoulboy
Stage I
Default Battery change
Hi guys
Need to change the battery on my FXDC Super Glide Custom 2013 Anniversary Model.
My question is;
Will I have any problems with the HD factory fitted alarm system when I perform this operation?
TIA
Old Sep 27, 2018 | 12:10 PM
nevil's Avatar
nevil
No problem unless you hook it up backwards.
Old Sep 28, 2018 | 04:26 PM
fxrnutt's Avatar
fxrnutt
Just have to reset your clock ...
Old Sep 28, 2018 | 07:59 PM
Bluesrider.df's Avatar
Bluesrider.df
Just make sure you connect the thingamjiggy to that whatchamacallit.
Old Sep 29, 2018 | 01:28 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Something I read the other night, if you have remote security fob let the bike go into "off alarm/security" then before it arms the security mode pull the Maxi-fuse. Remove the battery, negative cable first then positive. Did you fully charge the new battery? Install the new battery, positive cable first then negative cable. Clean cables prior to re-connection. Install Maxi fuse. Should be good to go.
HDJIM1158
Apr 23, 2015 05:19 PM
markkoby
May 21, 2011 09:18 AM
dirtdobber
Mar 25, 2009 05:49 PM
relli
Aug 16, 2008 09:53 PM
rkc06
Mar 6, 2006 10:43 PM
