fork oil measurements
Old Sep 30, 2018 | 06:58 AM
bbqbrisket's Avatar
bbqbrisket
Default fork oil measurements
This question only pertains to bikes that do not have spring tension on the upper fill cap of the forks.
I'd like to check the fork oil quantity without a drain and refill.
Has anyone ever done a ruler measurement of fork oil with the cap off from top down to the fluid line to find out how many inches to the fluid?
If so, let me know how many inches you came up with.
Thanks
Old Sep 30, 2018 | 09:33 PM
crusader1xxx's Avatar
crusader1xxx
Not that I know of. The reason most people do their own work is that way they know exactly how much is in there.
but why do you want to measure it? Is there something you feel is wrong? Solution to a problem that didn’t exist?
If it was me, depending on how long the oil has been in there, would do a full fluid and seal change. You could also up grade your suspension etc at the same time.
Old Oct 1, 2018 | 05:12 AM
Dynaglide92's Avatar
Dynaglide92
Thanks
you measure the oil when the fork is compressed (on a jack wheel removed) or you’ll get a false reading. Since you’re already there might as well just drain and refill to spec.
Old Oct 1, 2018 | 08:35 AM
Sisu's Avatar
Sisu
Mine were off by 4oz. from the factory. They were new and I found out with a spring change. I didn't like the dive my Fatbob had.
Old Oct 2, 2018 | 11:28 AM
FRANK121's Avatar
FRANK121
Anyone want to share the procedure?
Ozark Joe
EVO
54
Jan 15, 2017 06:36 AM
ncdan
Jul 8, 2011 12:22 PM
nb472
May 14, 2008 07:25 AM
aaron
May 3, 2008 06:12 PM
Grayhawk
Jul 15, 2007 08:21 AM
