Range, A and B odometer readings???
Old Sep 30, 2018 | 08:58 AM
mgb1's Avatar
mgb1
Default Range, A and B odometer readings???
Hey Guys. My 2012 Switchback all of a sudden started giving wrong readings on the Range, A and B odometers. The Range states something like 939 miles and A and B are 434 miles. These readings do not stay the same either, they vary and A and B can be reset to 0 by disconnecting the battery for a bit, but not Range. Only to have them go back to incorrect readings within a minute or so. Everything else on the bike seems to work fine and the bike runs and cranks fine. The DTC codes are "P1632, odometer learned up" , PN34271-12A and PN67096-12 .I can clear all of them out. Any ideas out there? Thanks
Old Sep 30, 2018 | 01:30 PM
Robottom's Avatar
Robottom
Found this on another forum:
P1632 is Odometer Learned up. - the good book says - This code is set when the speedometer mileage is higher than the mileage in the ECM. The ECM will set the code and increase its mileage to match the speedometer. This will normally occur when the ECM is replaced or if continuous battery is not present on terminal 18 of the ECM. If this code is set, verify the speedometer or ECM have not been replaced with a used part from another vehicle. Clear the DTC. If the code returns,the ECM may not be powering down properly.
And (wrt P1632) on this forum:
https://www.hdforums.com/forum/ignit...er-vision.html
Also (wrt PN34271-12A and PN67096-12) found on this forum:
https://www.hdforums.com/forum/engin...ad-hurter.html
Old Sep 30, 2018 | 01:36 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
It is truely amazing what can go wrong on a Harley these days.
jonnym61
Jan 12, 2025 08:17 PM
mgb1
Feb 16, 2019 06:00 AM
mgb1
General Topics/Tech Tips
Nov 13, 2018 10:30 PM
LUEPNITZ
May 8, 2013 04:07 AM
Locmoss
Aug 11, 2008 11:02 PM
