Best fork springs??
Old Oct 5, 2018 | 08:46 PM
03fxdlkid's Avatar
03fxdlkid
Stage II
Default Best fork springs??
Looking to upgrade my 39mm dyna front end fork springs. What are the best ones? Race tech? Progressive? What are other people running
Old Oct 5, 2018 | 10:03 PM
crusader1xxx's Avatar
crusader1xxx
Traxxion, Legends, ohlins....
Old Oct 5, 2018 | 10:14 PM
Stingray702's Avatar
Stingray702
Im thinking about going all Race Tech on my FXR. I've heard nothing bad about their G3-S rear shocks and their front shocks aren't too expensive either..So yeah..I'll be going Race Tech
Old Oct 6, 2018 | 03:00 AM
union53's Avatar
union53
A spring is a spring regardless of brand. Differences in springs are the spring rate which is how many pounds or NM it takes to compress it an inch, then how its wound, and length. You can get a straight rate spring which will be consistent in compression rate up to coil bind or a progressive wound spring where the force needed to compress the spring will increase as the spring is compressed. So given two springs of different brands that are wound the same and are then same length, they should perform the same. What goes in any particular bike depends on the rider, the bike, and how it's going to be used.
Old Oct 14, 2018 | 06:58 PM
Pylot7's Avatar
Pylot7
I would almost be willing the bet that there are only one or two actual manufacturers of springs. So you just get a different label depending on who you buy from.
The good thing about Racetech is they will talk to you and recommend a set for you and your bike.
Its worthwhile to take a look at emulators when you do the springs. I have a pair of Ricor Intiminators in my FXDC. My next step is to get a set of springs. The emulators do better with straight rate springs and the oem springs are progressive.
As I have been doing some homework on the topic I am getting springs from Racetech for a winter upgrade.
Old Oct 14, 2018 | 08:59 PM
crusader1xxx
Actually, companies like Race Tec, Traxxion, & ohlins made their own springs. Some others like Drag Special etc probably not.
+1 on the ricor’s. Been running them and Traxxion springs and it’s night and day for the better difference
Old Oct 14, 2018 | 09:02 PM
S&S145's Avatar
S&S145
I like Both *RACE TECH & PROGRESSIVE*....am running Progressives in my 03 Dual Disc DYNA Anniversary and Race Tech in my 02 FXDX Sport .Both work great .
Old Oct 15, 2018 | 08:45 AM
tcazes's Avatar
tcazes
legend aexo. blows the competition out of the water
mrfikser
Nov 14, 2014 08:44 AM
128auto
Oct 31, 2013 09:41 AM
parabellum_9x19
Oct 11, 2013 02:31 PM
Austin Dave
Apr 14, 2012 03:07 PM
harley_jeff
Jul 17, 2010 07:02 PM
