Spark plugs
Old Oct 18, 2018 | 08:04 PM
180Tiger's Avatar
180Tiger
Default Spark plugs
Anyone using E3 plugs?
Old Oct 26, 2018 | 06:40 AM
Shop rag's Avatar
Shop rag
Use NGK... E3's are a gimmick.
Old Oct 26, 2018 | 12:13 PM
SMFtwstdHICK's Avatar
SMFtwstdHICK
I picked up some basic Auto Lite (4164) plugs that I am going to try. Heard they about as equivalent as the Harley OEMs.
Old Oct 26, 2018 | 09:52 PM
crusader1xxx's Avatar
crusader1xxx
I believe Harley brand plugs are made by champion. Just remember just cause it says Harley on it, does not mean it’s made by Harley. Last time I looked Harley didn’t have an oil refinery....tire factory,...
Old Oct 27, 2018 | 08:01 AM
F86's Avatar
F86
I've used Autolites for years. One thing to be careful about: The screw-on terminal top will get loose, and may cause a reduction in performance when it does so. I've tried several things... I used to just grab the top with pliers and make it super tight, but it would eventually come loose still (except the one that I made too tight, and the insulater cracked). Next I tried a drop of blue loctite, but the environment of high temps and vibration wasn't right for loctite. I seem to have it permanently solved now, though... I have a very small lock washer (same diameter as the terminal) under each terminal, tightened until the washer is flat. They haven't loosened up since...
Old Oct 27, 2018 | 09:02 AM
archergodwin's Avatar
archergodwin
Plugs are like oil... choose the one that is rated for your ride and buy from your favorite vendor.
You want a better/hotter spark?.. upgrade your coil....
Old Oct 27, 2018 | 07:13 PM
brownie4412's Avatar
brownie4412
I bought a pair of Pulstars at a swap meet because they were cheap enough that I figured I'd give them a try. Ive been running them since February and I can tell zero difference between them and the champions I took out. As long as its correct for your application, a plug is a plug is a plug.
Old Oct 27, 2018 | 08:04 PM
cggorman's Avatar
cggorman
This ^^ has been my experience as well. The more exotic plugs do tend to last longer, tho. If it takes 4 hours to change your plugs (FWD V8 car, fer example), by all means go $$$. For a Harley? $4 and 4 minutes...do it every year and still be money ahead. LOL
BKSinAZ
Oct 5, 2025 07:21 AM
TUFF LUCK
Oct 11, 2018 07:54 PM
mrammo
Feb 16, 2012 05:53 PM
boblkat
Apr 11, 2011 07:13 PM
maconusmile
Exhaust System Topics
May 30, 2007 11:53 AM
