Errors and kicking out.
Old Oct 23, 2018 | 05:16 AM
stilup's Avatar
stilup
Default Errors and kicking out.
Bike sat for a few weeks while both me and the weather got better. Started fine but upon entering the highway twisting the throttle I get a engine slow then pick back up with engine light on.
I didn't stop there and it kept running so I went on thinking it just needs a good run. I stopped foe gas and it took four tries to startup but it did and I kept going. I twisted the throttle to give it a clean with the new gas. It ran fine.
I returned home after a couple hours. Then yesterday after work I did the diagnostic and got some errors:
PO 131 Front 02 sensor low (lean)
PO 132 Engine running rich
PO 151 Rear 02 sensor low (lean)
PO 261 Front Injector Open/Low EFI
PO 263 Rear Injector Open/Low EFI
Pn 32919-076
I'm thinking to try a new relay to start.
I have been running the Cobra auto tuner even though I did the cams and it has run fine but this year I did another exhaust swap and I get a bit of popping on deceleration but other than that it has been terrific for three years with the other exhaust.
I have done all my own work so far and I;m thinking to upgrade the tuner to match the cams. I may bite the bullet and have an Indy do it but I don't know what tuner I want.
I tried searching the Pn the daig gave me but I can't find it.
Old Oct 23, 2018 | 09:32 PM
archergodwin's Avatar
archergodwin
32919-076 may relate to the ECM itself. You may have a loose plug.. check your autotuner hardware install.
Droxxic
Jul 23, 2018 01:13 PM
Antonio Balls
Jun 13, 2014 07:29 AM
timinfla22
Apr 30, 2011 06:15 AM
jimmers1817
Aug 21, 2009 01:13 PM
ubreal
Aug 12, 2009 02:05 PM
