2018 FXBB console and indicator lights
Old Nov 21, 2018 | 01:24 AM
cycler's Avatar
cycler
Default 2018 FXBB console and indicator lights
This is probably a dumb question. I love the way the 2018 fatbob speedo/tach with indicator lights look with the 2018 and newer fatbob. Is there any chance that this set would work with a 2011 super glide custom. I'm looking to delete the dash and either get the BBC dash cover or KNS Customs dash delete cover. And mount some sort of either oem Harley speedo and tach dual setup using a dual dash gauge set up. And covering the stock oem dash with a BBC or KNS dash delete cover. Or use the dakota digital set up or the motogadgets moto scope pro set up. While using the 11 inch hardcase performance risers.
in a nutshell could the 2018 fatbob speedo tach with indicator lights somehow be used with a 2011 superglide custom? Or should I just stick to the dual oem gauges. Dakota digital or motogadgets gauge
Old Nov 21, 2018 | 04:02 AM
Frédéric CM's Avatar
Frédéric CM
I'd love to put the new '18 Street Bob speedo on my '14, but I remember someone tried and it didnt worked
Old Nov 21, 2018 | 04:15 AM
cggorman's Avatar
cggorman
I'm not sure when the CAN bus came into play but that's a consideration. I think cvaria tried a new gauge and it didn't work, but that may not be a definitive answer. I recall thinking that swapping pins around in the connector may have been a possibility.
I've got a Motoscope Mini and Motosign on my 99 and it works great. Definitely NOT plug-and-play though. Are you willing to hack up your wiring harness? And then there's that CAN bus question I never had to work thru.
Old Nov 21, 2018 | 02:18 PM
Frédéric CM
Canbus started in 2012 for Dynas
Old Nov 22, 2018 | 12:00 AM
cycler's Avatar
cycler
Default can bus
I wouldnt be the one hacking up the wiring harness. That would be left to my buddy. If anything I would buy a new harness in case he hacked up my old one so much that it was ruined. But what would have to be done in order for this to work? What parts would need to be bought and what gets hacked up?
Old Nov 22, 2018 | 03:07 AM
cggorman's Avatar
cggorman
Probably best to just read the installation manual...
Motoscope Pro with Breakout Box B, I assume?
https://motogadget.com/shop/en/motos...?tab=downloads
Old Nov 24, 2018 | 02:15 AM
petefwa's Avatar
petefwa
The gauge set up on a new Street Bob is just another reason l'm seriously thinking about moving on from Dynas.
cycler
Dec 7, 2018 12:35 PM
cycler
Oct 25, 2018 06:53 PM
blink1968
Feb 23, 2015 05:34 PM
clc3251
Jan 23, 2011 12:06 AM
de79
Aug 18, 2010 08:22 AM
