Moving lower shock mount forward?
Old Dec 9, 2018 | 03:33 PM
theduroche's Avatar
theduroche
Default Moving lower shock mount forward?
Okay, so since I haven't had enough people berate me for my other dumb questions, here goes:
Would moving the lower shock mount forward on my FXDX make handling better or worse?
i.e. would being more vertical help or would being further away from the rear axle hinder?
Here's what i already know:
- I can't move the upper mount rearward due to my saddlebags.
- I would have more clearance
- it's a harley, not a gsxr
- I could just buy a better set of shocks (no money)
- the FXR chassis would handle better (I'm trying to beg, borrow, steal one)
I'm just wondering about the mechanics of it.
Thanks in advance.
Old Dec 9, 2018 | 03:41 PM
Kingglide549's Avatar
Kingglide549
How far?
Why?
You will be loading the swing arm more between the axle and the front axis pivot, so that is a good thing.
It might raise the bike up (seat height).
Old Dec 9, 2018 | 08:24 PM
MotoArts's Avatar
MotoArts
Define "better". What are you trying to achieve?
Generally speaking, it will simply raise the rear end, decreasing the steering head angle (slightly). That will quicken the steering, just like raising the fork tubes in the triple clamps. Rear spring preload or damping will not be affected.
Of the 50+ street and dirt bikes I've owned and raced around on over the years, I don't see any radical changes when I do move the forks in the tubes. I'm certainly no suspension guru, either.
Old Dec 9, 2018 | 08:44 PM
theduroche's Avatar
theduroche
Mostly I was curious if that would raise the *** end and therefore "quicken the steering".
So question answered there.
Also possibly stiffen up the rear a bit, and maybe give the shocks more of a chance for when I've got the wife on board.
Old Dec 9, 2018 | 09:32 PM
AJ88V's Avatar
AJ88V
I'm on the prowl for a good deal on some higher-performance shocks that are slightly longer to get some ground clearance while steepening the head angle (reducing rake and trail for quicker steering.
But in the meantime, I've been thinking about doing exactly what you propose as a test by installing lowering blocks but flipped forward instead of rearward. These are available pretty cheaply for the Dyna. Here are some for my model and year:
Dyna rear shock lowering kit Dyna rear shock lowering kit
The response from MotoArts is mostly correct except that the EFFECTIVE spring and damping rates will be slightly changed. Move it forward of the stock position and the spring rate and damping will be higher due to the shorter lever arm from the swingarm pivot to the shock mount. The reverse happens if you move the shock mount points rearward (using those lowering blocks). For example, if the distance from the swingarm pivot to the stock position of the shock mount is 12" and you move the lower shock mount forward 1", the shock spring and damping will increase by 12/(12-1) = 1.091 or 9% more stiff. Move it rearward and it's 12/(12+1) = 0.92 or 9% softer. (haven't measured the actual length - preceding numbers are just for explanation)
In the end, installing those lowering blocks flipped around might work for you, but the correct answer is to buy longer shocks.
Old Dec 9, 2018 | 09:34 PM
theduroche's Avatar
theduroche
Thanks for the tip(s)!
Old Dec 10, 2018 | 07:03 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Thanks in advance.
"The more you have a cantilever (angle) on your shocks, the smoother the shocks will operate."
You will be stiffening up the suspension, and the shocks will not operate as smoothly. You will gain some rear height, resulting in a bit quicker steering. See Report on Rake & Trail HERE.
HERE is a Report on Rear Shocks, with a bit of why & how they work and why it is important for a good ride quality AND improved handling.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Dec 10, 2018 | 02:10 PM
Jake707's Avatar
Jake707
How would you move the lower mount forward? If you want more travel why not just get the 1" shock mount extender
http://www.bungking.com/swing-arm-lift-kit/
Old Dec 10, 2018 | 02:21 PM
DTTJGlide's Avatar
DTTJGlide
Just save the money on moving the mounting position & put it toward some longer & better shocks, you get what you want & your wife will thank you.
Old Dec 10, 2018 | 10:13 PM
AJ88V's Avatar
AJ88V
Good read. Here's the book I used when modifying my old sporty into a cafe back in the early '90s:
Motorcycle Chassis Design: The Theory and Practice Motorcycle Chassis Design: The Theory and Practice
I wasn't aware of this product. This design looks like it raises the shock mounting point directly above the original mounting point, thus not changing the lever arm like moving the lower mount in front of the mounting point. In this way, the shock spring and damping should be pretty much unchanged from the stock config.
