Throttle body size recommendations for 124 motor
Old Dec 16, 2018 | 01:40 AM
cycler's Avatar
cycler
Default Throttle body size recommendations for 124 motor
I have a 107 in my Dyna with head work, cams, high flow air filter, exhaust, lifters, pushrods, clutch and tune. I have the stock throttle body in this 107 build. I thought Id be happy but who is, especially when my other Harley SG is a 117 pushing out gobs of torque and hp which make the dyna seem slow. If I pulled the plug to buy a S&S 124 ( at cost through my brother and sell my 107 build). What size throttle body would be recommended? Ive read some guys say keep the stock size. Others said tthe 58mm that either S&S or others make. While a few other said the 66mm, although they were less that the 58mm crowd. The argument for the 50 and 58mm throttle body with a 124 motor was that air flow was stronger because of the smaller throttle body and didnt choke the motor. I would think the 58mm would be the middle ground and optimal. But id like to hear other opinions
Old Dec 16, 2018 | 03:53 AM
misfitJason's Avatar
misfitJason
Call HPI
Old Dec 16, 2018 | 04:38 AM
Frédéric CM's Avatar
Frédéric CM
+1 on HPi, at least a 58mm
Old Dec 16, 2018 | 08:50 AM
Sisu's Avatar
Sisu
At least a 58mm on a 124".. If it's the high comp engine with 640's I'd be tempted to run the 66mm throttle hog. It's a hot rod dyna, let it breath..
Old Dec 16, 2018 | 09:57 AM
NORTY FLATZ's Avatar
NORTY FLATZ
Rethink this statement.
Old Dec 16, 2018 | 10:37 AM
cdonis's Avatar
cdonis
I run a se58. No problems. Hpi makes some great stuff, and I have a friend using the 66 hog. So its your choice.
XFXDX
Nov 11, 2021 10:59 AM
usmcsteeler
Engine Mechanical Topics
May 3, 2017 11:35 AM
Denver Dave
Exhaust System Topics
Jun 20, 2013 05:26 AM
speedracer
May 24, 2012 06:41 PM
rodmodder
Aug 15, 2007 03:56 PM
