DFO Adjustment
Old Jul 4, 2007 | 05:47 PM
Jimbo59's Avatar
Jimbo59
Default DFO Adjustment
Ok, this one is for all you folks out there who use the DFO/TFI.
So I got the unit all hooked up, and preliminaryindications are that I even hooked it up right
Now, as far as my bike goes first thing I should mention is, that the only mods I have on the exhaust are;
Rush slip-ons (1.75)
and thats it.
No freer breathing a/c (Ness,,, SE S-1)
Now Iimagine that without the better a/c I wouldn't notice much change inthe way she runs. Took the green pod and rotated it toright around the 3-4 position at high idle after she warmed up.
Here is where my non fuel system inclination kicks in. The instructions say that the yellow light & pod serve as the accelerator pump, and the red light & pod serve as the main jet.
So when adjustingeither one what should be done? The yellow flickers when I crack the throttle, and at high rpms the red kicks on. Again not sure what I should be adjusting to here.
Do youopen the throttle to 3-4 K rpm and adjust (yellow & red)?
Or, do you adjust those at a high idle as well?
Finally, where should those two podsettings be (in a perfect world) when you're finished?
Thanks folks, and,,, HappyBirthday Day America[sm=usa.gif]
Old Jul 5, 2007 | 08:44 AM
Jimbo59's Avatar
Jimbo59
Default RE: DFO Adjustment
This must be a really good question, or a really dumb question.
bump I know you guys are out there.
edmroadglide
Milwaukee Eight (M8)
24
Oct 10, 2017 07:54 AM
luckyOne
May 8, 2015 08:28 AM
Tamatau79
General Topics/Tech Tips
Oct 17, 2014 10:18 AM
Reverend
May 4, 2008 01:46 PM
sonar_chris
Feb 23, 2008 11:28 PM
