2014-17 FXDL Low Rider (Silver) Right Slider # 45500230
The 14-17 FXDL RIGHT Slider will function perfectly with your 07 left, but there will be a slight Casting difference between the two at the Cal mounting area. Most observers won't notice, but it could bother some **** owners If that bothers you, you'll need a set of sliders.
Your slider on BOTTOM ... Later model slider on TOP ... (of course I'm using Left sliders but same reference)
Thanks! I'm somewhat ****, but I'm also part Scottish...
I assume the reflector is removable?
Yup, double-sided tape. I usually hit it with a heat gun/blow dryer, then sometimes they can be pulled right off, sometimes some dental floss behind it helps. Fine steel wool and WD40 takes off all the residue afterwards.
If you want to avoid chemicals and abrasives, I have had great success with rubber eraser wheels like below.
