Dyna battery suggestions.
Old Feb 16, 2019 | 02:17 PM
Durham man's Avatar
Durham man
Default Dyna battery suggestions.
I was looking at this one but I have read they don’t last long.
is there an good aftermarket battery with more cca than the Harley oem (315 cca).
Old Feb 16, 2019 | 05:24 PM
cggorman's Avatar
cggorman
Is yours turning over slowly?
Stock compression? Compression releases?
Old Feb 16, 2019 | 05:44 PM
Durham man's Avatar
Durham man
Not ready to go lithium but that’s a lot of crank! Compression is set at 10.2 on my 103 and it has acr’s. It’s just time for a new battery. I thought I might go with a little more cranking amps. The Harley battery is a little sluggish sometimes. Thinking maybe a Yuasa. I remember tin cup spoke highly of that brand.
Old Feb 16, 2019 | 06:00 PM
cggorman's Avatar
cggorman
Yep, Yuasa is the gold standard for the AGM type.
Old Feb 16, 2019 | 06:16 PM
Durham man's Avatar
Durham man
What’s the cover spacer kit all about?
Old Feb 16, 2019 | 07:58 PM
ludville1's Avatar
ludville1
Yep, that's the one I got...works great!
Old Feb 16, 2019 | 09:40 PM
brownie4412's Avatar
brownie4412
I’ve always had good luck with Deka. The one in my John Deere has a mfg date of 1998, still cranking.
Old Feb 17, 2019 | 02:09 PM
rjo3491's Avatar
rjo3491
My Duracell from Batteries Plus is starting it's fourth season next month. I think it's made by the same company that makes HD OEM units.
Old Feb 17, 2019 | 02:30 PM
Durham man's Avatar
Durham man
Ordered the Yuasa with a new tender. $136 bucks total from 2wheel. A new battery from the dealer goes for $130. Thanks for all the good suggestions.i did get 3 years out of the first Harley battery and 4 out of the second. This without a tender. I Can’t complain ( but sometimes I still do)!!
Old Feb 18, 2019 | 08:04 AM
maydaymike's Avatar
maydaymike
I have the same Yuasa in mine. Its about 3.5 years old now, and cranks it as fast as ever. My bike lives outside under a carport in the heat and cold, and has never seen a battery tender. It's never gone for more than a week or so without being ridden though, either. You'll be amazed how fast it cranks over compared to the stock battery.
