1996 wide glide carborator /tuneing
Old Mar 4, 2019 | 02:59 PM
Im2cool4u9009's Avatar
Im2cool4u9009
Default 1996 wide glide carborator /tuneing
Hello finally got my 96 wide glide back togeather with the shorts vance and hines and a arlinness ac I got a new carb in the it with I belive 180 main and pilot is 45 my problem is it starts right up and will idle for a few mins. But then it will start to sneeze every few seconds almost die and keep idling . Now I dont have air cleaner on this is prob the main cause but could it be anything elts. ? That I should be looking for . Were is a good start point for idle screw and mixture screw.thanks guys
Old Mar 4, 2019 | 03:14 PM
mmesa005's Avatar
mmesa005
Aside from what is available in the Forum here is more good info and some videos https://cv-performance.com/harley_mixture_screw_tuning
Old Mar 4, 2019 | 05:10 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Get a dyno-jet kit for your bike/carb, and follow the directions to the letter.
Old Mar 4, 2019 | 07:02 PM
Im2cool4u9009
Would not having air filter on at the moment play a part in this too much air going in?
Old Mar 4, 2019 | 08:29 PM
Im2cool4u9009
I do know what your saying but I dont think it has to do with jets new carb and new jets and if their too big or small I have difrent sizes just trying to get a idea of what everyone thinks this might be before I RIP the carb apart agin.
Old Mar 4, 2019 | 10:27 PM
fxdlx's Avatar
fxdlx
Lean running. Check the carb/manifold boot. They wear flat in spots and leak, they're cheap enuf, just replace it if it's old. Check your vacuum lines. and or cap on the intake/carb vacuum nipples.
Check the manifold/head o-rings. Check the diaphragm in the top of the carb.
mbeall777
Carburetor Related
Jun 23, 2017 11:39 AM
JohnnyC
EVO
42
Jul 14, 2016 09:23 AM
kris0082
Carburetor Related
Oct 9, 2014 09:15 PM
Joshua Anderson
Exhaust System Topics
Aug 29, 2013 01:43 PM
roadrunner68
Sep 9, 2007 06:15 PM
