In the video that Eborjas showed, reckon its of Rob Carpenter the Harley stunter(?), it clearly shows that the crash bar sliding over the concrete joint without any sign of flipping. Its not a small gap either. Just sayin. I guess if you slide over a pot hole or hitting softer ground like grass and gravel, the bike would flip anyways with or without sliders sticking out... or a engine case for that matter. Im not sayin that sliders are immune against flipping...
If you have a lathe to male these, I assume you also a chainfall or hoist of some type. Strap up the top of the bike to the hoist and start laying it down until you get danger close. Then measure.
As far as the "flip"...who knows...but I can personally confirm a lowside can become a catastrophic highside as soon as you leave the pavement...without sliders.
Its just a small metal workshop I have access to, not a big fancy with that kind of lifts :P I think I will just start with 6" from the original bolt and go from there, laying it down and measure and stop when the gap between the exhaust and the ground is noice!
Let us know what the smallest size you can measure out is.
Maybe you can make me some small ones.
Thanks, but I already know this. Im also running the bungking crash bar. Looks? Haha, it looks much better without these sliders of course. Im doing it for the protection. The picture is just a reference for measure taken from bungking, I just added the red.
Like you said, maybe I should make it shortest possible, just long enough to protect my exhaust. Delrin by nature is very resistant to shattering under high impact and has a slippery quality, making it slip across the pavement as opposed to digging in and causing the bike to flip.
Actually poor impact. I machine hundreds of pounds of acetal resin every year. I would reinforce internally with aluminum.
Temperature Range:
6" Lengths: 0° to 180° F
All other sizes: -20° to 180° F
Tensile Strength: 7,690 psi (Good)
Impact Strength: 1-1.5 ft.-lbs./in. (Poor)
Hardness: Rockwell R120-R122 (Hard)
For Use Outdoors: No
Specifications Met: See table
Im not saying that you are wrong or right, but delrin has been used for motorcycle sliders quit a while now and the material is proven to work for this purpose. So the impact strength is poor, but still it wont shatter to million pieces but keep its shape more or less and slide. The description from my post about delrin its not saying anything about impact strength either...
Breaking into a million pieces is irrelevant, it's brittle and if cantilevered out more than an inch or two it will simply break off.
Yes it's a great material but so is UHMW. If I were to use acetyl resin I would reinforce internally especially at attachment points.
What is your purpose for these? Looks or actual protection? If those are for protection then they are way too long. Once those things touch the ground they will snap right off if you're lucky. If your unlucky they will hook up on something and get your bike spin and/ or tumbling. Generally the shortest you can make them where they will do their intended job of protecting the frame.
Ditto (If those are for protection then they are way too long)
Yeye, the picture is just for reference as mentioned further up. The length is discussed already and I dont see the point on commenting on that again.
You wrote that the tensile strength is good, so I reckon the chance for the delrin to bend is very possible instead of snapping off? I would say the impact in the first video posted is HARD, if the delrin didnt break off there then I think thats a good result. Imagine how big of a accident it has to be to break a delrin... I think the bike would be totaled regardless anyways...
I have a pair of delrin sliders in my hands, thats why im using it. Its nothing more then that, and I also know this is a proven material for the purpose im using it on... as mentioned.
