blinker problem
Old Jul 6, 2007 | 07:38 PM
Dookie's Avatar
Dookie
Default blinker problem
i have a little problem with my left blinker on my 07 dyna, yes it is a bob. everytime i turn the key on the left one starts to flash and you cannot turn it off with the switch, you have to press the right one to make it quit. The left one will not work when you press the switch, it will only flash when you turn the key off then back on?????? any help would be great. i don't know about letting the dealer look at it because i am sure they will say it is my new bar that have been on there for almost a year. (problem just started 2 days ago)
Old Jul 6, 2007 | 07:41 PM
Trotter's Avatar
Trotter
Default RE: blinker problem
Retrace your wireing
Old Jul 6, 2007 | 10:23 PM
WdGldDave's Avatar
WdGldDave
My WG did that until I found the spot where the wires were mangled under my rear fender on the left side. Once I cleaned up the connections and taped it and shrink wrapped it, the problems went away. Basically, the wires going to my rear turn signal came out of the bracket and rubbed against the tire until they were bare and shorting out. Take a look under your rear fender to see if the turn signal wires are in tact.
hadesvi
Electrical/Lighting/Alarm
Mar 15, 2012 06:59 AM
dhellyer08
Mar 18, 2010 02:55 PM
dmercer
Apr 22, 2009 07:44 PM
coop57
Mar 26, 2009 08:10 AM
PsycleFreak
Jun 11, 2007 07:13 PM
