Dyna build
Old Apr 12, 2019 | 08:04 PM
dannyboy910's Avatar
dannyboy910
Default Dyna build
I have a 2016 street bob with a stage one breather and a RR2 2-1 pipe with a power vision tuner. I ride around 3k RPMs and higher motor is stock but I want more power. I love you rip the throttle but I also do equal highway and city riding . I have a $2k budget. What cams and combinations can you guys shine some light on for me.
Old Apr 12, 2019 | 08:25 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
If you can wrench on the bike yourself, get a 107" kit from Fuelmoto. It's all in one kit. Everything comes pre-matched for the best results possible.
Old Apr 12, 2019 | 08:45 PM
dannyboy910
Looking at the fuel Moto 107 kit and the cams given I don’t have the extra money for ported heads. What compression and cams would you recommend keeping in mind I love to ride the hell out of it.
Old Apr 13, 2019 | 09:03 AM
TOE_CUTTER's Avatar
TOE_CUTTER
One way would be to install the SE 259e cam and recommended upgrade components, S&S premium lifters, adjustable push-rods, and shave the heads to 10.5 compression. That will use up your budget. That will definitely give you a bump in performance. Again, one way of doing it.
Dave
Old Apr 14, 2019 | 07:58 PM
Dyna100's Avatar
Dyna100
If your not in a huge hurry to get this done, I would keep an eye on the member market place of this forum. Some great deals can be had. I just sold an Andrews 48H,which would have worked great on your build,for $125.00. You'll definitely make that $2K go further. Also, you might want to think about changing sprockets to 30/68. You'll definitely feel the extra torque, and still be at a reasonable RPM on the highway
Old Apr 15, 2019 | 04:16 PM
dannyboy910
Dyna100 I will definitely have to keep an eye on the listings
Old Apr 15, 2019 | 08:04 PM
Jay Guild's Avatar
Jay Guild
Figure out what cam you want; find pistons at the bore you want and will get you as close to your target compression as you can; find a machinist who can bore and hone your cylinders, can install compression releases, and possibly deck your heads; clean up your heads; and install it all yourself and it would be about $2k for parts, gaskets, and tools. There will be some fine tuning to get the compression right like head gasket thickness and how much to deck the heads.
Old Apr 15, 2019 | 08:21 PM
Pylot7's Avatar
Pylot7
I got a Woods Bros 555 cam and roller lifters from Fuel Moto. See if they have a tune they will give you for the combination. Nice broad power band, never loads up and is now damm fast. I already have a 2-1 pipe and K&N air cleaner. But that's all for the motor mods. Nice streetable combo that does not require any added head work. You'd have enough left over for shocks and then some.
kryingame
Jun 28, 2019 01:54 AM
monster715
Dec 12, 2014 10:16 PM
Chaddilac
Exhaust System Topics
Jan 23, 2014 11:56 AM
Sage Counsel
Jul 22, 2011 12:38 PM
accura45
Dec 22, 2010 11:56 AM
