I'm going to replace the rear Drive belt on my 2010 Dyna Superglide I think the T socket is a T70? I'm going to search for one around town and a 1 and 3/16 socket I should have one in the garage somewhere lol. While I have it apart I going to put a Barnett heavy duty clutch spring in. My clutch slips under heavy load sometimes not all the time but wondering if a clutch spring will make a difference?
You should replace the pulley, pulley spacer, and all seals on the inner primary cover and transmission left side while the inner primary cover and pulley are removed.
Also inspect the shift lever and shift shaft splines.
Also.... .. inspect your clutch hub splines... they will be fractured. Probably a good 3/8" to 1/2" of them on the tranny side. Courtesy of the stock auto-ratcheting primary tensioner. I would add a new clutch hub and Baker attitude adjuster into the mix. .. of course, depending on budget.
You don't need to remove the front pulley to put on a new belt.
I'm not replacing the pulley it looks good I am just replacing the rear drive belt because it dry rotted "I leave my bike outside allot" I also bought the primary gasket set I have all the T fittings except the T70 because I work on my Mercedes allot it's nothing but T and E torx bits on a Mercedes and I half to start collecting standard sizes again everything is metric nowadays I had a ton of tools but moved to Kansas from Ohio so most of my tools are still in Cincinnati lol.
