07 oil leak?
Old Jul 8, 2007 | 07:53 PM
davidc's Avatar
davidc
Default 07 oil leak?
I cleaned my bike today and when I moved it in the driveway I noticed a dime sized oil spot. Went into the garage and checked the floor where I park the bike and there were a few of the same spots, I checked the underside of the bike and could not find any leaks. I cleaned the floor and went for a short ride came home and parked it in the garage. An hour latter I went into the garage to check it again and found another oil spot looked under the bike and right above the spot there is a tube in front of the rear wheel and goes up some place. I am not sure where the tube goes lighting in my garage sucks and I could not find a flash light that did not have dead batteries. Anyone know what that tube is for? and why is oil leaking out of ? The bike is a 07 Super Glide that is 3 weeks old with no engine mods.
Old Jul 8, 2007 | 08:54 PM
shoptroll's Avatar
shoptroll
Default RE: 07 oil leak?
That little 1/4" plastic tube that you see is a vent line for the fuel tank. It runs up along the backbone to a tiny filter behind the neck on the left side and then up under the console.
There is a vent hose on top of the transmission in front of the starter. It's a 3/8" sorta "S" shaped rubber hose. Check that. Your tranny may have been overfilled and it's pushing out there. Just a theory.
johnpace2
Apr 24, 2012 08:15 PM
WARG
Exhaust System Topics
Jan 17, 2009 02:44 PM
lionsqrne
Jun 19, 2007 07:11 PM
whitetrash
Apr 19, 2007 08:34 AM
sporty1200c
Nov 22, 2006 12:33 AM
