2016 Dyna Wide Glide
Old Apr 29, 2019 | 04:41 PM
shane1's Avatar
shane1
Default 2016 Dyna Wide Glide
Just purchased a 2016 Dyna Wide Glide and I have a question about the 103 high output motor. It currently has the stock high flow air cleaner. Would there be any benefit to adding this K&N intake?
https://www.amazon.com/gp/product/B07N8SMLNM/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B07N8SMLNM/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Here is the bike;
Old Apr 29, 2019 | 05:17 PM
Ciggysmallz's Avatar
Ciggysmallz
Stage IV
Definitely. You've already got pipes installed so that's a bonus. More air is always a good thing.
Old Apr 29, 2019 | 05:37 PM
Kevin R's Avatar
Kevin R
You would be better off getting a good 2into1 exhaust. Your loosing power with the short shots.
Old Apr 29, 2019 | 05:42 PM
shane1's Avatar
shane1
Don’t have the funds for that at the moment.
Old Apr 29, 2019 | 05:49 PM
user 7172984932's Avatar
user 7172984932
Be prepared to spend $400 for a tuner.
Intake will make it run lean. Dont ride without tuning it
Old Apr 29, 2019 | 06:25 PM
ludville1's Avatar
ludville1
I just added a K&N air filter to the HO intake and vented to atmosphere on mine. 2 to 1 Cobra exhaust and FP3 tuner...bam! Sounds and runs awesome!
Old Apr 29, 2019 | 06:33 PM
shane1's Avatar
shane1
Might just keep it as is for now then. Runs and sounds great. Not sure what the previous owner did, if anything.
Old Apr 30, 2019 | 06:31 AM
shane1's Avatar
shane1
Whats the benefit of venting to atmosphere and how do you do it?
Thanks
Old Apr 30, 2019 | 09:28 AM
ludville1's Avatar
ludville1
Thanks
For EPA reasons, hot, oily, oxygen depleted crankcase fumes are routed back into the air intake. Not good. Venting to atmosphere ensures getting a colder, denser, intake charge, also keeping the intake cleaner. Here's how I did mine. After removing the air cleaner cover and air filter, remove the factory rubber hoses from the breather bolts. Then I drilled 2 - 1/2" holes in the backing plate. Using 1/4" ID 1/2" OD fuel line, attach the 2 hoses to the breather bolts and secure with collet clamps. Route the hoses through the backing plate using a little silicone RTV to seal the back side. Then I attached the 2 hoses to a brass 1/4" to 1/2" T, and added a K&N 1/2" 62-1330 clamp on filter to the bottom of the brass T. There are other ways to accomplish the same thing. You could use a catch can rather than a clamp on filter, or simply route the hoses to the ground. There are also screened breather bolts available. I believe Fuel Moto has kits for doing this.
Old Apr 30, 2019 | 10:39 AM
rossWG's Avatar
rossWG
i remember when my WG looked close to your bike. Enjoy.
